ATI super dumper 917271 and vortech V1
Hi guys,
I tried to google it bu can't find anything.
I have LT1 96 engine I'm just about to finish.
I want to install 917271 ATI super damper but have two questions.
1. Am I OK to fit vortech supercharger pulley onto the damper? I know my stock damper had a arrow mark on it and I couldn't fit supercharger pulley properly.
2. Once I have the supercharger pulley installed is the offset going to fit my supercharger or do I need some spacers?
Any feedback will be much appreciated![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Thanks
Thanks
Hi guys,
Thanks
Thanks
first thing to over come is the id of the ati hub is larger than the factory piece. so to have 3 options to over come this problem.
1. custom lower pulley.(my 8.5" cost just under $300 from asp.)
2. have some one with a lathe cut the back of the pulley for the larger index ring.
3. have some one with a lathe cut a index wash that will press over the factory index ring.(this works and is how we ran ours for several years.)
second thing is spacing. the ati hub moves everything out further if you use a stock depth pulley. its right at 0.500" difference in spacing. my spacer checks right 0.485" so 0.500" plate should work fine.
third thing is clearance. moving it out helps with wires if your still running a opti and allows you enough room for a 4" inlet pipe with minor rubbing on the steering rack. down side to moving it out is how close to the radiator it is.
and a little advice i learned the hard way. don't try and run any wheel smaller than 2.75" on top. they just dont have enough grip area to turn them fast with out a lot of slipping. i went as low as 2.5" and only picked up more belt dust for the effort.
Thanks a lot, I followed your advice and now my supercharger pulley has been skimmed to fit on the ATI super damper tight.
That works perfect. Just need to buy new bolts.
However I have two more questions![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
1. Not sure if the hub sits properly. It is showing me 26mm / 1.02 inch as per photo. I tried to press it in more but seems like that's all I can get. I was using the tool made from the long threaded rod, nuts and old bearing as recommended on forum. This tool worked perfectly with my stock hub. I can try again but don't want to damage the crankshaft internal thread.
2. Looking at the design of this hub I cannot see the possibility of installing the crankshaft bolt unless I'm missing something. Design is totally different than stock hub. I have a used damper so maybe there should be a big washer in?
As usual any advise will be much appreciated.
Thanks
Thanks
this is the ATI part # for the washer that goes with the 917327 "damper kit" (mine is for the LT1 1996 OBD2 motor)
hub washer #953070 (I suspect the washer is same size as you need but you could contact ATI to confirm)
you can buy it from Summit or ATI direct.
in looking at your part # of ATI this is in the "application" notes.
Application Notes:Required spacer and washer provided with damper
not sure what the "spacer" is for but there is a diffrence in hub length between 94-95 vs 96 OBd2 motors, IIRC. Maybe that spacer is for the 96??
Thanks
Thanks
like ****** said it sound like your missing the big washer.
here is a pic of mine.
![](http://i702.photobucket.com/albums/ww27/BIGCAT7274/20130721_182420_zps57587a56.jpg)
Thanks for photo.
Can you please send me exact dimensions of the washer and the bolt?
Seems like it will be easier to make one than getting a washer from US as I think there is no distributor of ATI in UK.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
you might want to have it cut a little thicker than mine unless you can get it heat treated.
od: 1.966"
thick: 0.280"
bolt is 2.5" long.
