1994 z28 service engine light wont give code when scanning
i have a 94 Camaro z28 that has a ses light on and when I went to jump a and b terminal with a paper clip it would not work or blink but fans would come on. then I tried the cheap 32 dollar GM OBD1 plug in scanner did the same thing no light and no blinks. then I would try it again the ses light would come on and waited for 5 mins and light would not blink but come on with the fans running. This is starting to get me ticked off. is this a Computer being bad? intermitting wiring problem that's common?
Anyone that has had this problem that can help I would be gratefully appreciate it.
thanks
thanks
you bought a $32 paperclip that wont work on a 94 despite what some manuals say.
When I say paperclip you literally can use a paperclip instead of that peice of plastic on vehicles that will flash the code, but again this vehicle will not.
You need a scanner with a display.
Check out this https://ls1tech.com/forums/pcm-diagn...-scan9495.html
