Lt1 dies and starts randomly, now won't start at all
I had posted this issue before, but had no help. Hopefully I'll get better luck this time.
Anyway, I have a '94 Firebird Formula. When I first bought the car, I had no issues with it. Not even the slightest issue. Almost a week later, she shut off. It ran for only 10 minutes, and then it would die for the day. I replaced the ignition switch, ignition control module, and the coil. Still had the same issue. Then as a last resort, the distributor. Shockingly, the distributor fixed the problem.
About a week later, she shut off going down the road. I waited about 10 minutes and she started. A friend of mine told me to try wiggling the distributor harness. After doing so, (and after a few minute wait,) she would start. the wait varied every time. Sometimes, she would start after a 10 minute wait, sometimes 30 minutes, sometimes longer. Hell, sometimes she would start without even touching the harness. There was one time she started right after shutting off.
Well, this time, she didn't want to start at all. After waiting and waiting and waiting, (wiggling the wire, not wiggling it) she just won't start. I can't keep cranking it because the battery is getting low now. It is bad enough to where I had to leave it in the AutoZone parking lot.
I had a few ideas in mind.
1. Maybe the ICM is overheating? I was told this was common, although this one is brand new. (Apparently, the AZ in this damn town can't test the ICM. The one in my home town can but I can't get back there.)
2. Is it possible that the (brand new) distributor was faulty? After all, it IS an opti spark distributor...
3. Do I need to buy a new distributor harness?
4. Is it possible something is just getting hot?
I really need all the help I can get. This car is..... well, 'was' my daily driver. Now I have nothing to drive until I can get some help on how to fix this damn curse.
1. Yes, I know I call her a 'she'. In my opinion, all cars are ladies and should be treated like them.
2. No, I can't check it until I get back to it, which won't be until tomorrow.
3. I believe it was a new Cardone Distributor from Advance.
Not trying to hijack this thread, but I had a problem starting the car when I put some intake cleaner in one of the vacuum hoses last night. I might of been a total dumbass with it but what I did was sprayed half the bottle through the TB then the other half through the hose that goes from the brake booster. I let it sit all night, started it the next morning and it didnt want to start at first. The ignition came on, fuel pump on, but just didnt want to crank, popped the hood and a little stream of smoke came out near the battery(battery was checked at the time). After about 7 times of starting it, she cranked and ran poorly for 20 secs. Of-course white smoke came out of exhaust which is normal. The only question is how the hell does intake cleaner stop a car from cranking while producing smoke near the battery? Hope a thorough answer can relate to the OP’s problem.
If it is a cardone unit..check for a signal resolution code.
Security light poping on by chance?
The icm heatsink should have thermal grease on it or put some washers behind it to move it away from the head.
Actually, yes. The security light has turned on and off a couple of times during this issue. And the ICM does have the dielectric grease between it and the cooling bracket before the head.
The only reason i mentioned the security light is I once had an issue with my key vibrating and the injectors would cut off going down the road. No sputter just stalled.
I have read several posts where guys say it wont shut off if its already running but mine did. I started using my spare key.
SSRRR is probably onto something with the pump. But i would think it would sputter to a stall instead of just instantly shutting off.
The times I had opti problems the engine would no sputter stall(sometimes backfire)and not start for a while. If im not mistaken you can check the opti singal by just cranking the engine over without starting.
That would sound reasonable but if the fuel pump had shut down and stopped sending fuel, wouldn't it sputter at least a little bit? She doesn't do that at all. It's just an instant shut off, rather the car is at 35 MPH, 70 MPH or sitting still.
Village Troll
That's what I'm saying. Even with the pump shutting off there should still be enough fuel pressure to keep the engine running for a half a second or enough to tell you it's shutting down.
