More toruqe than a Dmax - Turbo LT1 Results
#50
Excellent build and results, when you dynoed it was it tuned yet or was that what you were having done? Also I have the same injectors as you did you have to modify the Edelbrock fuel rail mounts or did the taller injectors just fit right in? I'm in the process of a twin 67/67 turbo LT1 build and I can't wait to get everything done and back on the road. Are you going to run water/meth at all or not?
#51
Injectors fit fine with the edlebrock rails, no mods needed.
When I crank the boost more, I have a meth setup with two 14gph nozzles waiting to be used.
