changed plugs/wires... now CEL
Old Oct 4, 2013 | 05:41 PM
leadfoot4's Avatar
Originally Posted by ThatOneKid
Pilarpod: It just kinda fell out, the big part with the wire, not the part inside of the oil pan, or whatever it's plugged into. I tried to slip it back on, didnt try very hard, couldn,t get it.
The "thingy" in the oil pan is the oil level sensor, and the "thingy" at the left rear of the intake manifold is the oil pressure sensor. I know for sure the pressure sensor's wiring is via a weatherpack plug, and I'm pretty sure the level sensor is the same deal.
Old Oct 4, 2013 | 06:02 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Good catch!
Old Oct 4, 2013 | 10:08 PM
ThatOneKid's Avatar
Yay? Well, whatever it is is making my oil pressure gauge all wacked, it reads well past the 80psi, kinda like the gas gauge reads when its full. When I take care of the plugs tomorrow, Ill take a swing at putting it back on.
Old Oct 6, 2013 | 08:03 AM
leadfoot4's Avatar
The oil pressure gauge sensors are known to fail. (they're the round sensor, external to the engine). What year is your car? IIRC, the early model year LT1s had their pressure sensors tapped in somewhere above the oil filter, and the later cars had them mounted to a "T" fitting on the upper left side of the engine, behind/alongside the intake manifold.
Either way, if your gauge is acting wacky, it's the OP sensor that's your issue.
Old Oct 6, 2013 | 08:22 AM
ThatOneKid's Avatar
Its a early LT1, 1993. It is right above the filter.
Old Oct 6, 2013 | 08:23 AM
leadfoot4's Avatar
You're lucky!!
It's FAR easier to change it there, that the later models.....
