Oil catch can question
My catch can has a port on the very top and a port about an inch down from the top. The way I understand the whole concept of it is you want the oil to drop down. So it would make sense to put the inlet on the bottom and outlet on the top. Which way does the PCV flow on the driver side of the intake so I can route the 2 lines correctly?? Back to front, or front to back?
I think u are asking which way does air flow through the PCV? The crankcase pressure has to be vented and the PCV is between the valve cover connection and the intake. The crankcase pressure (blowby) flows out the vlv cover through the PCV (which meters it so flow is restricted and engine doesnt loose vacuum) and the intake which is the vacuum source.
Glad to read u didnt try to eliminate the PCV.
Hope this helps,
cardo
Hope this helps,
cardo
Vacuum for the PCV system is supplied at the front of the intake, under the TB (assuming from your screen name you have a 97). So, normal scavenging flow is from the side of the TB>RH valve cover>engine crankcase>RH side of intake manifold to PCV valve>front of intake>ingested with incoming air to combustion chambers. When vacuum is extremely low, flow may reverse out the RH valve cover to the TB. There is no PCV valve in the valve cover.
