Code help...
Old Oct 21, 2013 | 10:39 PM
saltwaterreefguy's Avatar
Default Code help...
Car runs like a raped ape... However read codes and I'm getting a 26 and 43.
Now I'm untuned running mods in sig.
No evap no egr no air could these code be to those mods or something completely different?
Thanks for the input as always.
Old Oct 22, 2013 | 12:05 AM
After doing more research sounds like one of the codes is related but not the knock sensor code any help?
Old Oct 22, 2013 | 08:42 AM
shbox's Avatar
http://shbox.com/1/4th_gen_tech2.html#knock_sensor
Old Oct 22, 2013 | 10:11 AM
Ed Wright's Avatar
9-Second Club
Cure the 43 code and it will be faster.
Old Oct 22, 2013 | 11:10 AM
Ed I've heard great things about your tuning I need to get in touch with you.
Old Oct 22, 2013 | 12:39 PM
KyleW707's Avatar
26 - Evaporative emissions canister purge solenoid circuit
43 - Knock sensor circuit
Old Oct 22, 2013 | 04:13 PM
ls6jay's Avatar
Does it have roller rockers? Stock knock module.
Old Oct 22, 2013 | 04:36 PM
Yes. Explain this.
Old Oct 22, 2013 | 06:07 PM
Ed Wright's Avatar
9-Second Club
Originally Posted by saltwaterreefguy
Yes. Explain this.
Never mind that, makes no difference. If yours is a '93, there is no other option. And that won't cause a knock sensor code even if it were a '94/'97. Properly tuned, the later models don't need one either. It's just a band aid. No knock sensor code from the rockers, just somewhat excessive knock retard.
Old Oct 22, 2013 | 10:31 PM
So basically I still have a problem or is it the rockers? I'm confused. Easily I guess.
Old Oct 22, 2013 | 11:06 PM
shbox's Avatar
43 is a knock sensor circuit issue.
Old Oct 22, 2013 | 11:34 PM
Yes I understand that but is it because of the roller rockers? Or Because something in that circuit is bad?
Old Oct 23, 2013 | 08:00 AM
Ed Wright's Avatar
9-Second Club
Yes, something is causing the codes. Rockers won't cause that code. Things like the wrong year model knock sensors when putting an OBD1 box in an OBD2 car. Cars with lower cylinder pressure because of big cam, lowered compression for blowers , higher octane than pump gas fuel, etc, anything that would make one less prone to detonate at start up @ idle will cause DTC 43 to set. Simplest thing is to do is shut DTC 43 off if any of those condition exist. Even octane booster can cause it. The PCM advances the timing at start up until detonation is detected. If it can't detect detonation soon enough DTC 43 sets. Then timing is retarded to protect the engine. Thus, if you are setting DTC 43, your car is slower than it should be.
Old Oct 23, 2013 | 09:55 AM
shbox's Avatar
Not sure you do understand. Rocker arms are not part of the circuit. It is an electrical malfunction. I gave you a link in an earlier post on how to begin testing. Have you done any of that?
