Underperforming le2's?
Old Nov 8, 2013 | 12:19 PM
sweetbmxrider's Avatar
Default Underperforming le2's?
Is this normal times for le2s with a big 385 lt1 thumper cam on racecar 11.1:1 scr running citgo 93 racegas?
I'm the ***** car...
I don't get why the mph and time change so much? Is it from the better reaction timing?
Old Nov 8, 2013 | 12:24 PM
bufmatmuslepants's Avatar
You 60-330 shows you spun on the first run, second run shows you hooked but must have let off since your 1/8th mph was higher yet 1/4 was lower. Reaction has nothing to do with ET. You dynoed 385 IIRC, which is a bit low compared to some of the higher (12.5ish) compression AI 200 cars. I definately think the compression is holding you back.
Old Nov 8, 2013 | 12:25 PM
H8R's Avatar
H8R
The 60ft time . You spun or bogged or something on the first run.
look at the 1/8th mile, you were almost a full second faster on the second run.
The car is rolling out pretty good.
Old Nov 8, 2013 | 12:28 PM
Shownomercy's Avatar
Man-Crush Warning
You should ditch those crappy stock castings and put on the LT4 top end kit, I think that should help.
Old Nov 8, 2013 | 01:03 PM
93M6Formula's Avatar
I remember when I read Summit catalogs from 1995.
Old Nov 8, 2013 | 01:12 PM
Man-Crush Warning
Are you saying they are bad? The "Hotcam" is a solid performer and it should easily do +425rwhp
Old Nov 8, 2013 | 01:53 PM
kgkern01's Avatar
Are you saying they are bad? The "Hotcam" is a solid performer and it should easily do +425fwhp
Fixed.
Old Nov 8, 2013 | 02:58 PM
Ed Wright's Avatar
9-Second Club
That car is very slow, but how can you say it is the heads?
Old Nov 8, 2013 | 03:33 PM
Puck's Avatar
He's trolling lol.
11.09 @ 115 .
Old Nov 8, 2013 | 04:11 PM
Man-Crush Warning
Cause aftermarket edelbrock stuff would be much better with like a GM847 for a pure "race" car.
Originally Posted by Puck
He's trolling lol.
11.09 @ 115 .
It is pretty slow for the mods it has, maybe the race weight is too little?
Old Nov 8, 2013 | 10:36 PM
stevo9389's Avatar
LOL @ Citgo 93 race gas
Old Nov 9, 2013 | 12:09 AM
stngh8r's Avatar
11.0 and 121 doesn't sound bad to me?
Old Nov 11, 2013 | 10:51 AM
I know, they didn't come from advanced induction
Old Nov 11, 2013 | 11:47 AM
Ed Wright's Avatar
9-Second Club
I've made some pretty good power with Lloyd's heads.
Old Nov 11, 2013 | 12:08 PM
Man-Crush Warning
Telling you, sell those lame nuggets and get yourself the LT4 topend kit, Summit says its guarenteed 440hp.
Then you will run like low 10s I think if you get a naws shot on it.
Old Nov 11, 2013 | 08:53 PM
HellTeeOne's Avatar
Did you slam on brakes before the 1/4 traps on the second pass?
Old Nov 11, 2013 | 09:12 PM
Ed Wright's Avatar
9-Second Club
Can't see a guarantee like that when you don't know how sharp the engine builder and tuner might be. Just because they will SUPPORT that much power certainly does not mean a given engine will make that much. More to it than having a local machine shop machine everything and bolting one together.
Old Nov 12, 2013 | 07:38 AM
Man-Crush Warning
probably would need an expert to adjust the valve train right?
Old Nov 12, 2013 | 10:30 AM
First pass I had 21 psi in the rears and spun, probably were a little cold too. Started hooking at 19 psi and a little more heat. That second slip I left the car in overdrive like a newb, heard it shift, and got out of it
The air was really good. I can't decide if I want to max this setup out or what....guess I have all winter to pile up boxes It was fun driving to the track, swapping wheels, running 10s, and driving home. Weight was like 3370 with me and around 3/4 tank. I thought it was pretty cool for little ole hand ported le2's.
Old Nov 12, 2013 | 12:26 PM
HellTeeOne's Avatar
Looks like you have a great running setup, congrats.
SR or HR camshaft?
