Should I get a bigger TB?
and I'm not sure if I really need it right now because all I have is a K&N CAI and a 3.73 rear end.
Do you think I should just go ahead and get it? Or will I get better gains going with something else?
How do they test up there?
Thanks for going through and helping me look for parts.
Could you provide me with links to the parts? I'm not to sure where to start looking.
I am one of your "Calif." tune cars, thank you. Have passed smog with both 350 H/C and now 383 with same heads but a "slightly" larger cam (466 XFI 218/224 @ 113 LSA) for the last 10 years.
I will add my CATS were replaced @ 100k mi with MagnaFlo (not $100).
smog test, especially with the new "STAR" system in force now, in Calif. require OBD2 cars to plug in to verify 19 items (some are visual) and run on rollers 15 MPH & 25 MPH. Have to be under on CO, HC & NO at both RPM's
my smog test print outs don't show any data for just "idle" test so doesn't seem to be part of the test
Roger
Some areas just check idle and revved to 2500 RPM, just sitting there. No rollers.
Muffler shops around here have universal $100.00 cats made of used "recycled" guts. Not only not efficient, they don't even smell good. LOL
the 58 TB is WAY down on the list of things to do on "your" car given the mods you note.
While it would yield no real performance gain now, you would also have to pull your intake and have it machine to open it to 58 mm, get a tune so your tranny does not die and also make physical "adjustments" to the TB (drill it) to get it to run right.
spend your $ on other mods first and wait until you have a 383 H/C motor along with all the other "supporting" mods. Then regarding a larger TB.....get a stock one re-bored to 52mm
