Random Low Oil Light
worst case it may be oil pressure being lost through bad bushings...
have you done an oil change lately?
if not do one, and cut the oil filter to see if it has any shavings....
good luck...
good luck...
The stock sensors seem a bit finicky. I will occasionally get a low oil light before a cold start in standby. If I remove the key from the ignition and reinsert it will always go away. I'll get out and check the level on the dipstick and find that everything is picture perfect so I'm guessing the factory sensors are just crap. If your level is good then don't worry about it.
good luck...
Bad bushing? What bushings?
Anymore opinions on bad sensor or worst comes to worst “pickup tube fell off”?
I've figured out to a science now, if you cycle the key to "on" and not start then back to off wait 2 or 3 seconds, cycle it back to "on" and then start it, it never pops up.
Haven't got around to replacing the sender yet to verify its the issue.
