Couple Hotcam Questions
#61
6300 is totally safe. I would say if you have full roller rockers, but tony (camaroracing12) has been doing it for years and got into the 11s on the entire stock valvetrain at 6300.
#63
get the 1284 "printo" ffel pro gasket for intake
you doing a cam swap, right?
if so you will also need a new pan gasket unless you don't rip the old one and can clean off the rtv to re-use.
many also replace the oil pump drive shaft with a metel one from ARP,
#64
Change the valve guide seals when you change the valve springs. Fel Pro p/n SS72861. Also I would reccomend you install a new oil pump drive stub GM p/n 1103868, that way you'll have new gears that can bed in together to avoid the cam chewing up the old oil pump drive gear.
#66
Perhaps you are correct. At this point I will never know as I now have an LS1.
#67
Are there any last things I'm forgetting to get that haven't been mentioned in this thread? I'll be following the guide by Shbox. I'll be starting at the end of this week.
#68
"race" shops very often screwup street stuff because among other things they don't have any care or respect for it.
#69
And, if the guy installing it does not know, or bother to, degree it in properly the cam could be advanced.
That cam, when everything is right (including the tuning) runs hard past 6500.
#70
I have a stock cam, LT4 springs, 1.6RR's and other valvetrain mods, and spin to 6300 on a regular basis with 202K miles on the stock bottom end. You should be fine.
#71
Update: I got the cam swap done. It was definitely tough but I got it all done with little help so that's good, especially being a highschooler. One issue, it seems to idle high. It definitely doesn't lope like many other hotcam cars. I had the idle set at 850. Also when I'm shifting, I let off the gas but the car stays revved up and starts to slowly drop after 10 seconds or so. Is this something to do with the intake gaskets? I know I had overtightened them so I backed them out and re did them. Would this causes them to be smashed down and not seal properly?
#73
I think they're all good. No engine lights or anything. I had madz28 do the tune. What was your idle set at?
