Couple Hotcam Questions
the motor will most likely have idle issues which can be cumbersom when DD, especially in traffic. you can "drive" it but won't run as it should until the PCM is tuned.
I would find the $150 and send PM out whle you do the cam swap. Hot cam tune with some bolt ons is a pretty well known combo to qualified tuners
What was the engine setup and were the injectors stock?
Injector size swaps require tuning before the engine is even cranked, and far as cams go the LT4 is mild, and this guy is stock displacement yet.
The good news? It sounds great with a tune. This was my hot cam LT1 with tune by mad tuner :
1996 Camaro Z28 with LT4 Hot Cam Kit - YouTube
The dyno isn't needed or used for that area of the tune anyway.
Somebody competent at diagnostics should be able to find it. Could be many things.
With all the right mods the hot cam is just good fun.
