Help me build an lt1
That Hotcam will be ok and can easily make 350 hp at the crank. I wouldn't get the kit though; the springs it comes with aren't up to the task of supporting that cam's rev range. Any cam you do will require a tune to get much out of it. In fact, you should be considering a tune even if you stay with the stock cam.
Another thing to consider if staying with the A4 is a torque converter upgrade. It's almost a must with any cam swap and even yields a big performance increase with the stock cam.
If you want a really mild mannered cam than makes about the same power as that Hotcam, consider the Comp 502. For more power than the Hotcam, with about the same manners, go with the Comp 503. That's about as far as I'd go with stock heads. Better yet, call AI or LE and get a custom cam that can outperform any of the above.
While the engine is down, I'd get some thinner head gaskets to boost CR and improve the quench clearance. Something like the GM "Impala" gasket (.026") or aftermarket (.026-.029" range).
http://elliottsportworks.com/?page_id=32
http://advancedinduction.com/LTX/AiLTxCamKit.php
The kit you are looking at has springs that are marginal for the heavier LT1 valves and rockers that are 3/8" stud and limited to like .575" lift so they wont grow with the setup as you want more later.
6-speed swap will make axle damage a lot more likely so if you want to go that way start thinking about a 12-bolt or S60.
What are the pistons? Too often people "rebuild" LT1s and make complete junk of them
ill probably just stick with the a4 i dont want to stick 8 thousand into a 3 thousand dollar car. but i definitely do want a cam and headers exhaust and possibly a stall.
as for the pistons dont know. i had the machine shop short block it so i never had them out myself just know when i miked the cylinders they were 20 over and fresh hone marks
Then sell it as soon as you get the engine back together with the parts you already have. By the time you repair it, get a cam and stall tune, etc. you are going to blow by the $3000 mark before you know it and that is IF the tranny is good, and already has gears and exhaust, and the fuel system is still working well enough to support the extra HP.
if the lt4 hot cam kit springs are junk. what should i go for?
Change compression gasket match heads and
Intake ( GMPP duel plane) holly 750 and and comp cam 590 int/610 ex forget cam # but
Remember lift real nice stump puller cam
It's hooked to a 2.12 to 1 final drive gearbox
And with a 78 inch diameter propeller max rpm
Was 5600 that formula = 425 hp to the prop
Oh yeah it's in a 14 foot airboat so yes 350 hp
Is vary do able❕
Maybe the fuel pump is tired just from age, another $100+ there. ow about some suspension parts to minimize wheelhop so you don't break that glass axle the f-body got?
Still be nice to know what the pistons are because if the last owner put it together with stock cam and .020 over pistons it wouldn't surprise me if they are complete junk. A friend had an LT1 rebuilt before I met him and the "performance" shop used an $80 set of pistons that is a giant leap backwards from stock and they lowered compression on the engine a good half a point.
