LOUD Comp rockers (Update!!)
Old Jan 18, 2014 | 12:17 PM
ascastil's Avatar
Readjusted the valves again one cylinder at a time 3/4 turn passed zero lash. Narrowed the loud side to bank 2. It was at this point I knew I had to see what was going on when the car was running. I rigged up a way to hang the coil packs and bracket over the head with valve cover removed. Started car and saw no oil coming out pushrod on exhaust #2. Removed pushrod, blew through it, reinstalled finger tight. Started car and as Im snugging the nut down the wonderful sight of oil flowing through pushrod appeared, ticking is gone. Fixed.
Old Jan 18, 2014 | 01:00 PM
SS RRR's Avatar
Village Troll
Good deal.
Old Jan 18, 2014 | 07:45 PM
LilJayV10's Avatar
Sweet man!
Old Jan 19, 2014 | 10:25 AM
1997bird's Avatar
Originally Posted by cardo0
Take a read of this from Crane: http://www.cranecams.com.au/index.ph...ent/article/59
cardo
The OP is not using a stamp steel or roller tip pivot ball style rocker arm
Old Jan 19, 2014 | 11:49 PM
cardo0's Avatar
U are correct. But the owner still needs to clearance the new roller rockers - do u agree?
cardo
Old Jan 20, 2014 | 01:11 AM
1997bird's Avatar
cardo
Unless the valve spring diameter is larger than 1.55" OD, he will not need to.
Old Jan 20, 2014 | 10:12 PM
cardo0's Avatar
Woooow, every roller rocker maintains that clearance. I didnt know thaaaat. ill take your word its truuuuue.
Thx to dropping in.
Old Jan 20, 2014 | 11:56 PM
1997bird's Avatar
Thx to dropping in.
Not all rocker arms will give you that much clearance, the Comp Cams Ultra Pro Mag rockers like the ones that the OP owns do. If you are running into clearance problems on full body roller rocker arms with springs under a 1.46" OD, then the pushrods are more than likely way too short.
