Guess HP for my setup
Old Jan 23, 2014 | 11:04 AM
Storm-N-Normin's Avatar
Default Guess HP for my setup
Having a setup put together. Looking to see if anyone has a similar setup or if anyone can guess what type of horsepower it'll put out. Here are the details:
383 Stroker 11.5:1 compression
AFR 210 Heads
236/248 .520/.540 113 LSA
Vic Jr.
830CFM Holley
Thanks in advance.
Old Jan 23, 2014 | 12:22 PM
DUDCOUPE's Avatar
Hopefully over 500rwhp
Old Jan 23, 2014 | 12:38 PM
93M6Formula's Avatar
Not even close....
Your run of the mill 383 with GOOD parts can make 400-450. A junk slapped together mess of missmatched parts will net you 350-380 roughly.
We can't tell exactly cuz it's a crap shoot, build it and report back when the car is dyno'd.
Old Jan 23, 2014 | 12:42 PM
englundjd's Avatar
bump your compression half a degree and get those heads ported and you'll have something pretty wild...
Old Jan 23, 2014 | 01:19 PM
Forgot to mention the AFR 210s are the ported competition version
Old Jan 23, 2014 | 01:48 PM
Catmaigne's Avatar
That cam needs more lift to take advantage of the heads and I think the Vic Jr will hold you back. The Super Vic would have been better if it's not a street car.
Old Jan 23, 2014 | 02:00 PM
ATK Engines's Avatar
AFR 210 Heads
Vic Jr.
830CFM Holley
Thanks in advance.
Your camshaft is not suitable and mis matched for your heads/compression, you are leaving A LOT of power on the table. I would get the flow numbers from the heads and then call Chris @ Straub Technologies and have him spec you a cam, he is the man! With the right camshaft, you should be good for about 550+HP/525+TQ @ the Crank.
Old Jan 23, 2014 | 02:33 PM
englundjd's Avatar
Probably needs a tighter lsa also... 113 is pretty wide for N/A
Old Jan 23, 2014 | 03:11 PM
nitrous2fast's Avatar
LSA really has nothing to do with it. Two cams with the same LSA can have very different amounts of overlap.
And I also agree that this build wasn't thought through very well. Might still be quick, but not like it should be.
Old Jan 23, 2014 | 03:15 PM
SwampWS6's Avatar
I would also say your cam is holding you back a lot. A custom cam would suit you better. A 113 LSA is more like a turbo cam spec. A 110 or 111 LSA for a N/A motors would work and sound a lot better. The duration is fine but the lift on it blows. Their are custom grind cams for stock motors that has more lift than that. I think lift around 570+ will give you the full effect.
96Capricemanager will post something shortly and tell you exactly what you need to do.
But im guessing around the 395-425rwhp. Maybe???????
Old Jan 23, 2014 | 03:24 PM
SwampWS6's Avatar
You dont think so??? Why does So many builders require a tighter LSA on N/A and a looser LSA and FI cars?(I know my answer just wondering what your is?)
Old Jan 23, 2014 | 03:59 PM
DUDCOUPE's Avatar
Originally Posted by 93M6Formula
Not even close....
I hav a 350 and it makes more power on a dynojet lol
Old Jan 23, 2014 | 04:03 PM
DUDCOUPE's Avatar
Smh, nugget builders
Old Jan 23, 2014 | 04:16 PM
englundjd's Avatar
well not to hijack but whats your build DUDCOUPE?
Old Jan 23, 2014 | 06:27 PM
SwampWS6's Avatar
Lt1 350, stock pistons, crank, rods, lunati cam, ported stock heads. Made enough hp for what it is
Okaaayyyy......?????? How much rwhp????? Do you have any ET times???? Whats your CR?
Old Jan 23, 2014 | 07:03 PM
Puck's Avatar
Out of the box comp 210s with a 236/248 cam will make ~425-450rwhp through a t56.
Step up the cam and hand port the heads and you can hit that 500rwhp mark.
Old Jan 23, 2014 | 08:14 PM
Purple Poncho's Avatar
. Maybe???????
For ****'s sake, please stop.
Old Jan 24, 2014 | 04:32 AM
madmike9396's Avatar
No et yet track is closed, cr is idk, zero decked and made 413 on a mustang dyno which is 470 on dynojet
I don't see how you get that ? between the mustang dyno and dyno jet around here they is only 20 rwhp difference with the dyno jet being higher
Old Jan 24, 2014 | 07:23 AM
SwampWS6's Avatar
And who the **** are you may I ask?
Old Jan 24, 2014 | 07:27 AM
Shownomercy's Avatar
Man-Crush Warning
lulz @ different type of dyno numbers.
Race your car or stfu about dyno numbers. No one cares.
