misfire or hitting rev limiter?
Old May 11, 2004 | 12:42 AM
ram air camaro's Avatar
Default misfire or hitting rev limiter?
i was almost certain that it was my tranny that had crapped out but i went the track this past friday and something unusal happened spark's or fire was coming out of where the cutout is under the car when the car was missfiring for about 1/2 to a 1 second of pure hissitation .\
what do guy's think is that a missfire or is it the tranny hitting rev limiter ?
i have a 94z28 automatic trans
i have reviewed numerous of time's through my camcorder
Old May 11, 2004 | 12:49 AM
Vendetta's Avatar
umm... where were you in the RPM range? I'm assuming up top? I don't really understand your post, are you sure it was a backfire and not you dropping your tranny? I'm assuming the tranny shifts fine now that you're asking us this question?
Well if it was a backfire, In my opinion a misfire is most likely since the absence of spark would dump a decent amount of unburnt fuel into your exhaust. The unburnt fuel particles in your exhaust would then ignite due to heat, and cause the backfire.
What mods are done to your car? How high do you rev? Does your ignition miss often?
Old May 11, 2004 | 01:09 AM
it's in the high rpm's right before it's time for the next gear to shift.
well it shift's perfectly when driving normal but on full throttle it hisitates for almost a complete second and then it shift's. would you call that a missfire?
sorry for not making sense i have very poor education being brought up in a small town. i rely on you guy's on figuring out my car problems since the nearest profesional mechanic that knows about working on camaro's is a about an hour away.
my mod's are:
230/236 cam at 112 lsa with 1.6 roller rocker's installed by me.
tci ssf 3500 torque coverter
header's and a bunch of common bolt on's
one thing though my water pump is covered with oil?
Old May 11, 2004 | 01:18 AM
Vendetta's Avatar
Hmm...
Sounds to me like your tranny is about to buy the farm. If it's delaying a shift it might be a slip that you're experiencing. If there's oil on your waterpump, perhaps some spilled or there's a leak somewhere. It could have gotten to the opti and caused a misfire...
A misfire sounds like a slight pop coming from your motor and a delay in acceleration. It happens when no spark gets to the cylinder that i supposed to be ignited, usually due to a plug, wire, or opti. How's your gas mileage?
I really don't have any solutions to the tranny, could be a quirk or something due to the TC, I'm not sure. I'll let one of the other guys handle that....
Old May 11, 2004 | 01:28 AM
well how you defined it, i know it's not a missfire it sound's like tatatatatata but say it really fast ..
if there was just a way for you to here a sound clip or the video. thank's on the reply.
gas mileage suck's after the cam! well i also pay $2.45 a gallon here in cali
Old May 11, 2004 | 06:39 AM
OneMeanZ's Avatar
Missfires suck...
Old May 11, 2004 | 07:01 AM
onefunlt1's Avatar
hey my 93 auto does this... When I go from a complete stop and just matt the gas it smacks the rev limiter at 5700 and hesitates to click second??? I've got a B&M shift kit new sprag and clutches, and a vigi 3600. I actually flushed the tranny recently and it seemed to help a little bit but it still loves that rev limiter.
Old May 11, 2004 | 11:04 AM
that's kind of what mine does.
Old May 11, 2004 | 12:53 PM
-PEPE-'s Avatar
maybe after you get the tranny fixed if it's needing work get your pcm tuned for whatever performance mods you've done, if you haven't already. Get the rev limited adjusted from 5700 to 6700, also check your 02 sensors.
Old May 11, 2004 | 01:32 PM
i got pcm for less tuning , i my revlimiter is set shift at 6400 rpm.
i'm buying a used tranny off a guy from the board is there any thing i could do the tranny so it could be heavy duty. he also including a electronic shift kit not b&m.
i'm just going to be dissapointed if it's not the tranny but i guess i could sell it. i paid over 1400 to get rebuild 30,000 miles ago which has no more warranty. but i guess i could alway's sell it.
could it be my tci converter it's a 3500 i think
Old May 11, 2004 | 05:16 PM
Vendetta's Avatar
I would suggest replacing it with a used Borg-Warner T-56 from an LT1 car. They're far more stout than the LT1 4L60E and quite a few enthusiasts believe that they are far stronger than the Tremec T-56 found in the LS1 cars. There is a guy named Taner Bosnali on this forum running 9.60s in the 140s, cutting 1.2 60's on a BONE STOCK BW T-56 (except for clutch).
Old May 12, 2004 | 06:40 AM
OneMeanZ's Avatar
So the 94 6 speeds came with Borg-Warner??
Old May 12, 2004 | 11:20 AM
Vendetta's Avatar
Yup
Old May 12, 2004 | 11:48 AM
Default 4l60e
i got a guy offering me a manuel valve body with a shift kit 4l60e is this a good tranny to throw in?
i'm sticking to a 4l60e dude's i would like to use my tci 'verter
Old May 16, 2004 | 09:42 AM
z28s's Avatar
dont forget a rear end and a street twin if your going 6-speed, the stock rear wont last long doing 4000-5000rpm dumps..also Taner has the viper upgrade for his 6-speed
Old May 16, 2004 | 03:40 PM
DietCoke's Avatar
Nothing's wrong with your tranny, or your car. Your problem is a 3500 stall in an OBD-1 car. There isn't any surefire/good way around it. The computer reads the stall as slippage, and doesnt shift the trans until after you hit redline (for a second or more in some cases) which is what your experiencing.
Old May 16, 2004 | 04:22 PM
(DIETCOKE) so your saying that it's my pcm not reading right?
is there a cure for that? because my transmission shift's perfectly while driving in the city and i would hate to spend extra money on trans and and then resulting not being the problem.
Old May 16, 2004 | 08:09 PM
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
yes Tony, but it did go 9.60 on the stock output shaft, last year. of course it was cryo'ed
Old May 16, 2004 | 11:28 PM
DietCoke's Avatar
When your in the city, your never going to hit redline, so it's never an issue. Consider converting to an OBD-II computer system
Old May 16, 2004 | 11:50 PM
so everybody with a obd-1 car that has a high stall like mine has this problem also ?\
i guess i'll call brian at pcm for less and see what he can do for me if that's the case.
