12-1 or13+-1?
I would put a flat top piston in it with .035 quench and live with whatever compression that nets you. In modern chambers domes hurt flame travel.
You can get into the 12 range on pump gas depending on the cam.
My point was I think there are MUCH better places for this guy to be chasing power than racegas compression levels.
I mentioned the lift simply because that is not much lift compared to what most of the quick street/strip LT1s are running so it suggests the cam is not particularly aggressive and I feel he could probably gain a lot more optimizing other things than he is going to get with jacking the compression to a point where fuel costs double and is harder to get ahold of.
