Least restrictive LT1 induction?
Here was my solution:
I have no data to say whether the new intake is an improvement or not. I just dl DataMaster and need to pick up a cable to be able to data log. I also have not gone WOT just in case it does flow that much better, I do not want to create a lean condition. I have plans to dyno tune the car soon though. That is a 4" to 3.5" coupler from TB to MAF, then the MAF, then 3.5" to 3.5" coupler to 3.5" exhaust pipe. MINIMAL hood bracing notching was required and a little flattening of at the top radius of the pipe...This fits under a stock 95 hood as well. It's the first prototype so it's not the prettiest but it seems to function lol.
Only thing I don't like about your setup is yours is sucking hot air off the radiator, that's kinda the whole purpose of the block off plate and location of the K&N intake; keeps the air charge nice and cold. I'd be interested in what readings your IAT sensor has now vs. K&N setup.....my guess is any restriction gains from eliminating the 90 degree elbow is negated by hot intake air...scan it! Maybe try to get the filer another 6" closer to the ground.
As soon as the cable from TunerCat comes in the mail I will data log both intakes.
I put the CAI off my car on it at the track with no filter, car ran the exact same times with and without the CAI(no filter or MAF).
You have a different issue I think.
The size difference in the elbows alone is huge....and it tuns out the little honeycomb thing in the MAF had fallen into the old little G2 elbow and was shaking around in there
My MAP went down as low as 92KPa at it's worst point and the tuner said a Moroso CAI can hold steady around 94-96KPa. Sooo that being said I may convert to the LS1 lid setup.
Well did u take into consider the MAF relocation? GM calibrates in the stock location with the stock elbows and bends. MAF sensor is very sensitive to the pipe that feeds it and where it sits. If u have a fix for this please share.
cardo
cardo
