95 neighbor question
The kit he showed me has 2 solenoids (Fuel & Spray), all the supporting hoses, grounds, and 6 jets (50-100-150---300), button and a 10 pound bottle.
Anyone have a write up so I can help this dude before he blows his **** up.
I told him 100 shot is the highest I personally would go on stock tune + stock manifolds. Once I told him he’ll need long tubes to get the best out of the kit, he was short on money from the move. Last edited by 93Euphoria; Feb 15, 2014 at 07:08 PM.
anyways... Duh nailed it pull fuel off the schrader valve
install the nozzle between the throttle body and Maf, not before it the maf
get the guy to invest in a window switch and a WOT switch so he doesn't accidently activate it in the low rpm
Elaborate on what you mean about pulling the fuel Schrader valves. I need detailed info so I don’t blow this guys motor.
aint going to work on this one! Elaborate on what you mean about pulling the fuel Schrader valves. I need detailed info so I don’t blow this guys motor.
aint going to work on this one!The schrader valve is a test port on the back of the intake, it's where you hook up a fuel pressure gauge.
The schrader valve is setup like the valve stem of a tire, just take the valve out and find the correct fitting to connect your fuel line to the valve
doing it this way means you dont have to cut and splice the fuel lines
Just from the looks of it though it looks like he needs a new fuel solenoid. Half of one of the 2 wires is soldered onto it. Just barely holding on right on the part where the solenoid meets the wire.
The NO2 Solenoid is fine and actually has a bracket.
Anyone have any pics of there 2 solenoids bolted on the top of their fuel rail bolt?
I want to help this guy out and at the same time, I could learn a thing or 2 about spray along the way. It may not be my car that is at risk, but the whole thing is my risk since I’m doing the work for him. And I can only depend on reading, hearing your guys good information that you take the time to give out, improving on what steps to take in order to not have this job half ***.
I realize the risk on the trans & motor. But its an insult thinking that is not in the back of my mind. He blows both then thats his fault. Fair warning.
Its no surprise that stock tuned LT1’s are recorded to take the abuse of 125 shot. But that is not my plan for his set-up. A Mild 50-75 wet shot is all he wants & is already ordering more parts needed for a clean set-up. In the mean time I finished the installation just to test out the whole thing. I did a basic set-up of a single fogger into the intake elbow. Both Fuel and Nitrous Solenoids are bolted on top of the fuel rails. The fuel Solenoid is routed to where you obviously check your fuel pressure at. Bottle is right under the the glove box (he only had enough hose to reach the NO2 Solenoid bolted on the front of the fuel rail), with bottle heater hooked in the pressure remained a steady 1050-1100. As far as wiring I tucked in both solenoid grounds & 12v’s in the wiring harness loom. The switch he had was a wide open switch but he wanted the option of hitting it at whatever time he wanted while in WOT.
Got done with the whole thing last night and took a good test drive with a 50 shot and and it had the most kick in 1st & 3rd, 4th. Assured the guy about the risks on a stock trans, and tune. We sprayed several times, never overheated, only WOT hits and no problems. But its in the obvious not to be as dumb as ricer kids and beat the living **** out of it when there are no mods.
The things he is lacking & what I think he needs is:
Arming switch
Fuse relay
A quality & conveniently accessible button
More extended NO2 lines to put the bottle in where the spare tire use to be
A tune, Injectors cleaned, flow tested & reconditioning, some timing pulled
Long Tube headers with EGR
Nitrous Outlet fogger plate in between the TB & intake
Along with a bunch of other things.
Anyways I appreciate the help guys regardless of all the pessimistic comments. Lol
