Charcoal Canister Delete Question
I have read a bunch about it on quite a bit of threads but could not find my answer exactly. What I'm wanting to know is if I remove the canister I am left with a feed, return, vent and the evap lines coming out of my sending unit, if the evap is deleted along with the canister do I now have two vents?
I see a bunch of people say to insert a breather filter on the evap, I'd assume just run a small section of rubber hose off the sending unit hard line with the breather on the end? The vent on the sending unit is currently setup the same but with no breather filter (been like this sense I bought the car). Does this sound right or am I missing something?
Thanks!
I'm in the process of installing PTFE lines and I'm just trying to cleanup the area back there.
I'll prolly put a small filter on later.
