more LTX ideas??
Old 03-27-2014, 06:37 PM
Tinbender59's Avatar
Default more LTX ideas??
firebird_1995 And I have been discussing this idea for a while, I'm up for doing the prototyping, If this is somwthing that will generate some interist. the idea is very basic, build 1 inch spacers to go between the block and the water pump, make an extended pump drive to still use the pump in the stock fashon. I am not sure how the electric pump to fan shroud clearance would be with this extension. theroyetically this would make it easer to change the cap/rotor, and or the whole OPTI with out pulling the waterpump. Input???
Old 03-27-2014, 07:16 PM
cardo0's Avatar
Default Good idea but will 1" be enough room?
The one inch spacers would be easy. Do u have an old water pump? U can just bandsaw slice off 1" of the castings water to block connections.
The shaft extension would be more difficult and require either totally new machined piece or a sliced up and re-welded splined shaft.
But why not use an electric water pump and plug the timing cover?
cardo
Old 03-27-2014, 08:17 PM
cardo
hum???? factory made spacers?? great idea actually!!! and Electric pump??? will it clear the fan???
Old 03-27-2014, 08:25 PM
jewbacca's Avatar
You might have some trouble clearing a Meziere pump, but a CSR with some clearancing of the fan assembly should work just fine.
Old 03-27-2014, 08:31 PM
Catmaigne's Avatar
The fan already had to be notched for my 50 gph JEGS water pump which is pretty much the same size as the HD Meziere. There's no way it could work for me.
Old 03-27-2014, 09:57 PM
jewbacca's Avatar
A CSR pump (what I've got) is much smaller, and doesn't require any notching when installing it.
Old 03-28-2014, 10:49 AM
Catmaigne's Avatar
Just wondering, how much space do you have with the csr? I'm already pretty far into the fan with my ewp.
Old 03-28-2014, 11:12 AM
sweetbmxrider's Avatar
Not a bad idea but I'm thinking of running a remote electric waterpump at this time. Get the whole mess the **** outta the way!
Old 03-28-2014, 11:50 AM
96capricemgr's Avatar
I wouldn't try it with a mechanically driven pump, would be really difficult to keep the drive straight and I would worry about excess wear to the bearings in the block and waterpump. Worst case you damage the bearing in the block you circulate metal. I do think it likely you would wipe the waterpump bearing first, but if the engine side bearing were damaged the cost could be serious.
Old 03-28-2014, 05:33 PM
are you talkin remote or the spacers??
Old 03-28-2014, 05:57 PM
DUDCOUPE's Avatar
The drive coupler would be the hardest part being youd want it level and balanced
Quick Reply: more LTX ideas??
