Smog problems with lt1 egr
High NOx means your combustion temps are too high (usually). Check your EGR valve for overall functionality. Get the car up to temp and push in on the valve (its hot). If the car dies or wants to die, its working fine. In that case, cooler plugs are a good first step. What are the other readings?
The egr will hold vacuum when the car is off but at idle will not. There's not enough back pressure to keep the egr open. When I pump with the mityvac with the car running, the egr vacuum will go up but come back down immediately.. unable to hold.
The egr valve will hold when car is not running though. It's a new egr valve with the right part number from AC Delco.
I tested the egr solenoid and vacuum hose from the intake manifold to the solenoid.. all working. So the prob is somewhere from the exhaust lines.
Just installed a brand new catalytic converter thinking it'll help, made no difference on nox numbers. But my HC and other numbers are really low and clean. Smog tech is convinced it's an egr issue.
I am in the process of testing for any leaks in that little pipe coming from the stock exhaust manifold to the intake manifold. Also gonna pull the egr valve off to see if there's an issue with as blockage there.
I can't think of anything else I don't have headers and have a stock cat. It's gotta be a blockage or a leak somewhere in the exhaust lines or passages that don't allow for proper back pressure to keep the egr continually open
But OP, wouldn't blocking the bleed holes in your egr valve cause it to never close on it's own? It's there so when exhaust back pressure is low it closes the egr valve right?
How exactly did you clog it?
I ran a datalog and plugging the bleed holes like op suggested and it shows changes in the rpm at idle it runs much rougher when egr is activated.
Also without the bleed holes plugged the egr valve doesn't open all the way since the negative pressure from the intake manifold was sucking the shaft and pintle back down which is why when I applied my mityvac it would show some vacuum but not about to hold.
Anyway the biggest test would be an actual smog test so I'll update my results.
Verbatim from the GM manual. And there's no such thing as "negative pressure". It's vacuum, or low pressure.
The negative pressure is the type of EGR valve. There are lots of EGR valves, 2 being positive and negative. The LT1 uses a negative pressure EGR valve that has a secondary spring that closes the lower diaphragm to the upper diaphragm in its default state. When the negative pressure of the intake manifold exceeds the positive pressure of the exhaust backpressure, it pulls on the hollow shaft and pulls the EGR closed. Which is why OP was able to bypass this by blocking the bleed holes.
http://shbox.com/1/4th_gen_EGR.html
"The 4th Gen F-body uses a negative backpressure EGR valve. The amount of exhaust gas is varied, depending on the amount of manifold vacuum and exhaust backpressure. This is why it is typical to get an EGR diagnostic code when the exhaust system is altered. Adding headers or removing the catalytic converter can create changes in backpressure. OBD-II has higher sensitivity to this and will "throw a code" more often than OBD-I will.
The diaphragm on the EGR valve has an internal vacuum bleed hole which is held closed by a small spring when there is no exhaust backpressure. The PCM driven EGR solenoid controls vacuum to the valve.
Engine vacuum opens the EGR valve against the pressure of a large spring. When vacuum combines with negative exhaust pressure, the vacuum bleed hole opens and the EGR valve closes."
This articles explains it further details http://www.tomco-inc.com/Tech_Tips/ttt27.pdf
When I don't plug the bleed holes, I can see the EGR valve open and then close rapidly unable to maintain vacuum because the intake manifold is pulling it closed due to lack of exhaust backpressure.
If you plug the bleed holes, it overrides this control unit inside the valve, essentially making it a regular vacuum EGR like you said.
The reason why positive/negative EGR valves were designed were because exhaust backpressure was a good way to measure engine load so that the EGR system doesn't cause the car to run rough or stumble. But I'm finding that plugging the bleed holes and just allowing only the EGR solenoid to engage the EGR valve is sufficient enough.
But I found a few other threads that talk about this. If you lack exhaust backpressure, the EGR valve cannot remain open due to the intake manifold continually pulling it open.
