FML: should have gone ls...
What we replaced and what with:
Replaced the "bad" GM Opti with a new Duralast Gold.
Replaced factory GM wires with new Summit Racing 8.0 mm wires.
Replaced all eight original plugs with new NGKs.
Replaced the original ICM with a new CarQuest one.
Replaced the original coil with a new MSD coil.
Replaced the two year old CarQuest alternator under warranty
Replaced the two year old Interstate battery under warranty.
New AC Delco waterpump (yes we got the o-ring on)
New Duralast thermostat
New GM thermostat housing
Replaced torn Gm elbow with a TrickFlow aluminum intake elbow
Replaced cracked GM intake box with a TrickFlow cold air intake
Other unrelated stuff:
New eBay foglamps with halos
New GM fender
Repaired front cover
At this point, I'm at a complete loss as to where to go from here. The original problem with the car was that it was becoming very hard to start, would run rough when first started, missed badly for the first minute or two of running, then would clear up and run strong. One day, it stalled on me going down the road at about 35 mph, then would not restart. It was raining that day. Also found that the thermostat gasket had been leaking and fluid was getting on the opti. This led to the opti diagnosis and all this work we just put into it.
Now, it again doesn't want to start, and misses very badly once it does start. Sometimes, it won't start at all, no matter how long or how many times you crank it. when this happens, it smells terribly of fuel. When it does start, it will not stall, but never clears up either, it continuously misses. we found last night that if you unplugged the harness from the second injector back on the passenger side, it doesn't change anything, while unplugging any other injectors cause the engine to stumble even more. Today, I swapped that injector (which looked pretty dirty when i pulled it) and the first injector (which looked extremely clean when i pulled it) on the passenger side, in hopes of finding the injector to be bad. It changed nothing. unplugging the second injector back still doesn't affect the engine while unplugging any of the others does.
I also hooked my fuel pressure gauge up to the rail. results were as follows:
initial pressure on hook up after sitting all night: 0 psi
pressure on key on, engine off: 41 psi initially, but slowly dropped as i let it sit for a minute. dropped to 37ish after about 3 minutes.
at idle: 38 psi.
Before, the only code that the car ever threw was something about the EGR system, but it did that for a long time before I ever started having problems. Now, the MIL is not coming on, though it does light up during system check on start up, despite the obvious miss.
The only other mods to the car that I can think of mechanically are the high stall converter, a hollowed cat, and a magnaflow muffler.
At this point, I'm stuck thinking towards bad wiring to that injector, or a bad cylinder on the engine. any other thoughts? The gas in the car is 8 month old premium, but it wasn't old when i parked the car for the winter when all this started happening. also, i started the car up and moved it a few times over the winter, and it fired right up and ran great when it was like 0 degrees out.
Thanks guys!
I would take a look at the plug wire on the dead cylinder, bet you melted it.
Many of your parts choices are really bad, wouldn't surprise really anyone here if the module crapped out already.
Always start with the basics!
