LT1 Water pump replacement help
Well now I am beginning to realize what a PITA a Lt1 is. My opti is in the way of my WP drive seal by about 1 cm. So if u want to change the $1 seal you have to pull the opti, drive belt, and somehow rip off that crank pulley with a tool that I don't have. I don't give a sh** anymore I am going to slap it back together with the original WP drive seal in place and hope it don't leak which of course it will because of murphys law. Mite as well rebuild and pull the whole engine when you have to change a water pump, stupid a$$ design. Lets not forget about the retarded opti location, oh don't get fluid on the opti "impossible!!! You cant stop fluids from dripping on it.
Oh how I wish I would of bought a LS1. Even better I would like to drop a TSBC in there.
I know one thing...the w/p seal will gush oil like you have never seen if it goes.
Lol, I had a day to cool off now. So how much work is it to pull the damper and opti so I can change the WP drive seal? Will I absolutely need a puller tool or can it come off with a rubber mallet? When the opti comes off do I need to change that seal too?
I bought the victor brand timing cover gasket kit that has the o rings, wp seal, opti seal in it. I hope victor makes decent seals because that's the only brand I can find around here. I know I gotta mark the SP wires so they go back on correctly.
