Plug Wires
Old Oct 1, 2014 | 05:09 PM
93BlackZ28's Avatar
Default Plug Wires
What are you guys with long tubes using for plug wires? I keep burning mine up on the headers.
Old Oct 1, 2014 | 05:57 PM
fleetmgr's Avatar
Put some of this stuff on them http://www.jegs.com/p/JEGS-Performan...30487/10002/-1
As long as they aren't laying on the headers, they should be ok.
Old Oct 1, 2014 | 07:25 PM
ABA383's Avatar
Look into routing the wires over the valve covers. When I did mine I had to piece together a "kit" but now you can find pre made kits online with looms, custom cut wires, etc. I ran Taylor Spiro Pros and Made For You Looms for SBC ran backwards..Best thing I ever did to keep the wires off the headers and I used black wires/looms to make it look as factory as possible. And I ran the large stepped Kooks LTs. Do a search and you'll probably find lots of pics..Its commonly abbreviated as OTVC wire kits.
--Alan
Old Oct 2, 2014 | 11:54 AM
BALLSS's Avatar
are your wires installed through factory looms & brackets?
Old Oct 2, 2014 | 03:26 PM
93BlackZ28's Avatar
Yes they are, but now that I've had to replace about 4 of them with cheapo aftermarkets, it's not so clean looking and I hate it.
Im thinking about doing this kit... but still don't know if I want OTVC
http://www.mcssl.com/store/cc-perfor...0349ca0572b4d3
Old Oct 2, 2014 | 03:36 PM
CamOnlyJabroni's Avatar
I used a combination of the Jegs wire spreaders. and also their brackets that you can mount to the side of the block. Once we initially got the motor running, I had the number 8 cylinder touching the header and caused a misfire. I just bent the bracket to fit the wires more snug to the block and have not had a problem since then.
Below is a link to Jegs site with what I was talking about:
http://www.jegs.com/p/JEGS-Performan...rPage=90&pno=1
Old Oct 2, 2014 | 04:14 PM
BALLSS's Avatar
Over the VC or other after market SBC brackets/looms I am sure would work fine. Anything that keeps them off headers
with that said I have used the stock brackets/looms a a couple of wire sets over the years and have never had a header burning wire issue. I use Magnacore wires and I had a Crane set before that
for your headers if boot ends are vey close you can always get those wire/boot socks noted earlier
yeah routing wires using stock brackets/looms is a PIA but not doing anything will often lead to burnt wires with headers
Old Oct 2, 2014 | 04:44 PM
93BlackZ28's Avatar
http://www.jegs.com/p/JEGS-Performance-Products/JEGS-Ignition-Wire-Separator-Kits/1270364/10002/-1?itemPerPage=90&pno=1
Linky no worky
Old Oct 2, 2014 | 08:06 PM
Link fixed
Old Oct 3, 2014 | 12:22 AM
lsxdick's Avatar
Taylor wires worked good on my 96 impala with cia longtubes.
Old Oct 4, 2014 | 02:39 AM
96LT1Z's Avatar
I am running these from WS6 store. Been great. Been on for about a year prolly. Zip ties are your friend.
http://www.ws6project.com/user_stor/...plug-wire-set/
Old Oct 4, 2014 | 05:37 AM
cardo0's Avatar
I really like my ceramic boot accel wires 9038C. Accel w/s says outa stock but summit says they have'm. http://www.summitracing.com/parts/ac...t/model/camaro
I used to buy fiberglass sleeving by the 20' roll for cheap from JC whitney but now they sell some $35/roll Mr Gasket stuff. I think the cheapest fiberglass wire sleeve now is the Taylor stuff (3/8"). But u can cut the sleeving to length and slid it over the wire for extra protection.
Good luck.
Old Oct 6, 2014 | 07:00 AM
94LTZ's Avatar
I used the custom MSD wire kits and ran the wires where I wanted from the bottom along with some heat sleeves and never had issues.
Old Oct 6, 2014 | 01:32 PM
Catmaigne's Avatar
Cheapo Jegs wires, some looms, a few ties, and come very careful routing. Never burnt a wire.
Old Oct 9, 2014 | 08:58 AM
speed_demon24's Avatar
Moroso wire looms.
Old Oct 9, 2014 | 01:47 PM
96LT1Z's Avatar
Originally Posted by speed_demon24
Moroso wire looms.
Where do you get those valve covers????
