My new 96 z28
Old Oct 16, 2014 | 07:47 AM
JOHNNYMO's Avatar
Colorado is as follows
regular unleaded- 85
mid grade-87
premium-91
Old Oct 16, 2014 | 08:32 AM
smitty2919's Avatar
Originally Posted by bufmatmuslepants
Put it on a dyno or take it to the track and lets see what it's really doing. Ill say...330rwhp and 13.4 1/4 mile just from what I can see and you've said.
If that becomes true, I'd be pissed with that number of 330 of of a FI car LOL. I have 311/346 on my Full exhaust and dyno tune 95 Z28 M6 lol.
I hope this works out for you. Seems be to a lot of "unknowns" and quirky information about this car having a supercharger installed.
Old Oct 16, 2014 | 10:06 AM
bufmatmuslepants's Avatar
Only one way to tell, but breathing through stock exhaust manifolds and no intercooler with a questionable fuel system and tune puts my guess where it is. Only one way to find out, take it to the track and see your mph or a dyno pull.
Go get some baselines in now then do it again after you fix that stuff. Then post back and well tell you how to fix it and get the real potential out of it.
Old Oct 16, 2014 | 10:36 AM
ahritchie's Avatar
You might as well go buy some longtube headers right now (and good gaskets) why bother troubleshooting an exhaust leak on POS stock manifolds. A blown LT1 needs to breathe...I wouldn't be suprised for it to pick up 40+ HP with the supercharger factored in. Then look into tuning, fuel system, intercooler/SC upgrades to make more reliable and add HP. A SC 383 it is being completely choked off by those manifolds; those are inadequate on a cam only setup...much less stroker+ power adder HP level.
Old Oct 16, 2014 | 12:21 PM
93M6Formula's Avatar
At this point i'd be surprised if it even has ported heads...
Old Oct 16, 2014 | 07:20 PM
3Whips's Avatar
No, Iowa lol. And I'm not a chevy guy i couldn't tell you if they're stock manifolds.
Old Oct 16, 2014 | 10:23 PM
Catmaigne's Avatar
Wat. 99.9999999% of manifolds are cast. This has nothing to do with Chevy.
Do they look like this?
Old Oct 16, 2014 | 10:52 PM
SS RRR's Avatar
Village Troll
mid grade-87
premium-91
Denver too? I don't remember, but am wondering if 91 is offered up in the mountains...
Old Oct 16, 2014 | 10:53 PM
TMTMTL's Avatar
need for speed underground paint!?
Old Oct 16, 2014 | 10:55 PM
TMTMTL's Avatar
SS RRR, high altitude in albuquerque is same.. 91 premium. same altitude as denver. they run 91.
Old Oct 17, 2014 | 09:23 AM
fbody_brian's Avatar
No, Iowa lol. And I'm not a car guy i couldn't tell you if they're stock manifolds.
there, fixed that for you
Old Oct 17, 2014 | 11:35 AM
  #32
3Whips's Avatar
Lmao no you didnt you acted like an *** hole, they're not stock headers. And no I know quite a lot about cars I just dont care for Chevy, Ford is better, and I'm not biased i own a dodge stealth, camaro, and mustang. I work on them all.
Old Oct 17, 2014 | 12:10 PM
  #33
3Whips's Avatar
LOL I haven't played that game in forever! That was on the ps2 and xbox wasnt it?
Old Oct 17, 2014 | 12:15 PM
  #34
3Whips's Avatar
Nope they do not, and I never thought the headers were stock until you guys kept going on about them. I'll post a pic of them soon.
Old Oct 17, 2014 | 12:31 PM
  #35
3Whips's Avatar
Ya don't think they're stock
Sorry bad picture doesn't show all of it
Old Oct 17, 2014 | 12:34 PM
  #36
3Whips's Avatar
It wouldn't make sense for this guy to build this all up and not change out the headers.
Old Oct 17, 2014 | 01:27 PM
  #37
ahritchie's Avatar
You are correct...those ARE headers, not manifolds upon closer inspection. You would be surprised at some of the things people do that don't make any sense at all around here....Like a Mustang/Mopar lover buying a LT1 Camaro of all things! Or this one time some crazy dude started posting on a GM based forum claiming "Ford is better".
Old Oct 17, 2014 | 01:31 PM
  #38
3Whips's Avatar
You are correct...those ARE headers, not manifolds upon closer inspection. You would be surprised at some of the things people do that don't make any sense at all around here....Like a Mustang/Mopar lover buying a LT1 Camaro of all things! Or this time some crazy dude started posting on a GM based forum claiming "Ford is better".
My opinion, you have your's I still respect Chevy, but it is not my favorite. My favorite is Ford, then Mopar and then probably GM.
My Uncle was a body man, he's heavily into Mopar.
Are the current headers acceptable for this build? Or should I get better ones?
Old Oct 17, 2014 | 01:38 PM
  #39
Alex94TAGT's Avatar
Those are indeed aftermarket headers -- not stock exhaust manifolds. They just happen to retain the factory emissions equipment (secondary air injection at least), which isn't surprising on a California-based car. They should be fine.
Can you see any model numbers on the Paxton head unit? 8~9psi on a 383 isn't shabby for an older Paxton. If I knew the pulley sizes and step-up ratio, we could calculate the impeller speed to see if you're overspinning it at all, but it's probably not a terrible idea to rebuild it with fresh bearings either way.
Despite not knowing all of the specifics, I'd run 91 (premium) at minimum, preferably higher if available. Don't want to run cheap fuel, being non-intercooled. Your compression, final ignition timing and IATs will have a large effect on when detonation hits.
I like the paint.
Originally Posted by MEAN LT1
I think I see "Versa Fueler" You have three Big injectors in front of the throttle body to help with the fuel needs of the motor.
You mean Superfueler. The Superfueler came with the Paxtons and added the extra injectors up front. Versafueler is a peak-and-hold driver box for 8 low-z injectors on the rail (which would otherwise fry the PCM drivers due to excessive current).
Old Oct 17, 2014 | 03:08 PM
  #40
3Whips's Avatar
I like the paint.
SN2000 is the supercharger model i believe
