Starting Problem (With Video)
Old Oct 14, 2014 | 07:50 PM
ak422's Avatar
Default Starting Problem (With Video)
https://www.youtube.com/watch?v=OMYq...ature=youtu.be
This is what it does every time on cold starts, on hot starts its fine, I have a big cam in there but I wouldn't assume it would be doing this?
Also another question I have is when I switch into 2nd or 3rd gear it seems to misfire BADLY I don't know if that's the opti or ignition coil going bad?? Also I just changed the plugs 6 months ago along with fuel filter and IAC valve
any help is appreciated, I just want to get it running like new again
Old Oct 14, 2014 | 07:59 PM
davidc212k's Avatar
it could be a bad opti or ignition coil, but i would get it scanned for codes 1st and go from there. specially since you are getting a service engine soon.
also you might need a tune with a cam, but get it scanned for codes before you start to throw money at it.
Old Oct 15, 2014 | 10:41 PM
SS RRR's Avatar
Village Troll
PCM been tuned? Usually a backfire is caused by a timing issue.
