lt1 parts
With an LT1 intake a 250hp shot should be direct port.
Properly ported LT1 heads with a 200 shot should put a f-body into the 9s. Guessing your boss is clueless as to just what kind of performance a good LT1 with 250shot can provide. There is one guy with ported LT1 heads on a stock short block with a carb in a third gen running mid 9s on I think 175-200hp shot. Another guy with the same ported LT1 heads on a stock short block Impala runs 10.4 on a 75 shot.
If he wants a catalog answer trick flow heads let the pistons in the engine now help dictate which Trickflow head, you want at least 11.5:1 compression, LT1s can go higher even on pump gas but this should be rock bottom minimum for a built LT1. Far as intake,the stock one is not perfect but hard and expensive to beat, the only Bolton aftermarket is Edelcrap, don't even consider it for a second, their heads and intake for the LT1 are a bad joke making less flywheel hp than a ported stock heads setup is expected to make at the tire.
if the port job was "home done" by someone that just happens to own a air tool with some grinding bits...not the way to do it.
maybe a pic would show otherwise.
places like Lloyd Elliott Portworks or Advanced Induction would be better to get/discuss heads...and even a matched cam for a nitrous build
From the sounds of what he did those heads....sell em off or toss em out
Big gaping hole wow..stick it on the bench see what happens
Who knows what his intentions were so its hard to armchair and be critical I guess
See many putting them down whats so bad about them? A good single plane cost money too.
The intake was halfassed when the GM LT4 intake was discontinued and everyone was clambering for something, the magazine testing suggests the edelbrock intake might possibly HURT power a little. The GM LT4 intake is internally an LT1 intake anyway.
One of the magazines did the Edelcrap kit plus NITROUS on a Caprice and it ran the same as my car did, on my old 190cc heads 226/234 .565/.565 cam full weight on street tires with the slicks and tools in the trunk.
I suspect they just recycled emissions legal gen 1 ports and stock the LT1 was such an upgrade from earlier 23degree that the end result is their LT1 stuff was a joke.
What size chamber is the 11.3:1 compression based on? That is too low.
If you want to do aftermarket most diehard AFR fans will even tell you the small AFR stuff is not worthwhile. Doing as cast heads is a poor idea too.
I would look at Advanced Induction ported Trickflows bought through them, pretty good value vs. buying something then shipping it out for porting.
The issue with the edelbrock intake is the air gap, it takes away plenum volume, which hurts power more than the air gap helps. This is very well documented by Lloyd Elliot himself, as well as dyno and 1/4 mile comparisons. Yes a single plane is costly, but that has also only been proven beneficial over a well ported stock intake over 6500rpm, and has less power below that. It's only wise to use a single planes on a motor with a non stock PCM since the stock PCM can only go to 7000rpm.
