Seals are STUCK!!!
Screw driver trick didn't work for the WP drive seal either? Am I going to have to saw the seal into pieces or drill it to get it out? I also am trying to be careful not to scuff the cam drive or the timing cover. Any ideas?
the seal removal tool shown in this thread should "easily" remove the seal. Make sure the hook part is not catching part of the TC. Just work the tool around the seal it will come up
On the WP drive seal, just use a small screw driver and hammer and punch the screw driver through the top of the seal and pry out
FYI both Opti & WP drive seals install "dry"..no oil.
