throttle body upgrade
Old Nov 13, 2014 | 07:25 AM
criticalx's Avatar
Default throttle body upgrade
Heads+ cam+ intake+nitrous is it time to upgrade tb yet?
Old Nov 13, 2014 | 09:32 AM
95sscamaro's Avatar
I did figured it couldn't hurt, I got the TPIS 58mm, only thing is you have to get the intake port matched to the TB.
Old Nov 15, 2014 | 10:45 PM
BALLSS's Avatar
get pcm tuned for the larger TB...
Old Nov 16, 2014 | 08:53 PM
zstr28's Avatar
Absolutely, tpis says the 52mm tb is good for 325-480hp range. If you have the stock 48mm you will definitely gain some hp and throttle response.
Old Nov 17, 2014 | 06:23 AM
96capricemgr's Avatar
Don't worry about what TPIS says.
Far as throttle response that changes because 5% open on a larger bore is just more air than 5% on the 48mm.
If content with 52mm I would have a stocker opened up, if going 58mm understand most,require some mods to make the IAC circuit work right.
Old Nov 17, 2014 | 05:40 PM
nitrous2fast's Avatar
Heck with making it right....
Old Nov 18, 2014 | 06:27 AM
moehorsepower's Avatar
Yup And this can be a pain in the A$$ tuning wise, trying to make it idle if the mod isnt done....
Old Nov 19, 2014 | 07:03 PM
Kevin Blown 95 TA's Avatar
If he has an A4, the pressure tables should be adjusted or the pcm might not command the pressure it needs at a certain power level since pressure tables look at the throttle angle and there is less throttle angle for the same amount of air flow. Especially with a 58 mm TB.
Old Nov 21, 2014 | 07:27 PM
BALLSS's Avatar
OP
any larger TB will require PCM tuning...you will need scan tool to read IAC counts as you chase your idle issues. The "drill" mod is often required with aftermarket TB's as they don't have the air inlet hole or same passage as stock 48. Another way is crack blades open some and slot TPS holes to move TPS back. I don't subscribe to that method but some do it to get larger aftermarket TB's to idle right.
if you are in need of a larger TB, get the stock one re-bored to 52...
