96 TA Shut down at speed
Today I had the Trans Am out on for a drive up hill, I was going about 30 when the engine started to stutter. I gave it some gas (6 speed, in third gear), and it died a few seconds later. Tried to start it back up, couldn't get it to turn over for a few minutes. When it finally did start back up, I had to keep it basically floored in neutral to keep it above 1000 RPM, after a few seconds of pumping the gas to keep it alive it finally died again. It sounds like a fuel delivery problem, like a clogged fuel filter or a weak fuel pump, but over the summer I put in a new Racetronix pump and a new filter. The car has only gotten a couple hundred miles, if that, since summer. Anyone have any idea what could be causing this? Could the filter have gotten clogged while sitting? This is the first time the car has died at speed.
