Trunk mounted battery
Curious-where on the body did you ground the battery negative? Are you planning a heavy body to engine block jumper in the engine bay?
If my garage is ever above the like 15 degrees it is now, I'll be getting back to putting my car back together. Included is running battery cables from the rear. I'll be using the right rear seat belt mount for the battery negative.
I'm using the Odyssey ER40 and I got it to fit under the spare tire cover-along with a plug-in air pump.
"Valve Regulated Lead Acid (CRLA) batteries like the Odyssey depend on the internal recombination of the gases for proper operation. ...It is not uncommon to see these batteries in aircraft, hospital operating rooms and computer rooms."
I believe the Optima is the same as they state: "Completely spillproof, mountable in virtually any position"
There is venting in these cars in the rear compartment and at least for these batteries, I see no need for a sealed box.
I think Mr. am_muscl is in pretty decent shape here with his installation.
Your ground should be to the unibody rail where your wrench is resting. Your engine ground should go to this rail as well and be the same size as your power lead.
Would suck to get booted from track of sloppy install of battery relo.
Just saying.
Good call.
