MAC MID Headers a good choice?
good ground clearance
good fitment/ plug access
1 5/8 header helps with low rpm torque, 1 3/4 seems a bit big for my bolt on LT1 which usually sees rpms less than 4000.
Not sure if I would want to keep my air/egr or delete it all and clean up the engine bay a little. No emission checks here in Michigan. I have read that even with Mac Mids that bolt on LT1's can still get 290-300rw.
I would consider long tubes if heddman or summit actually makes a good fitting 1 5/8 LT header for the LT1 that doesn't smash the floor board when you floor it!!! It just sounds like all the trouble of LT's aren't worth the hassle when mid length headers have very few issues?
Also can you change the clutch in a m6 without pulling the header out of the way? I know some cars have this issue.
The biggest drawback to them is the fact that they have individual flanges, rather than the one-piece flange that most other headers have. When you take them on and off a time or two to fix leaks, they end up being tweaked because each primary is "independent" of the others, not having a one-piece flange to hold them all true to shape. The result is eventually leaks that are increasingly difficult to fix.
They were on my car for 7 years or so and perhaps 60k miles. Leaks weren't an issue for the first 4 or 5 years. Ground clearance was just as good as stock. Plug access was better than stock. The car made 290/327 SAE on the dyno back then, with stock engine and stock programming; and later made 358/370 when I added a cam, valvetrain upgrades and a tune.
They're a good choice of header for those who want stock-like ground clearance but still good power gains. They're much better than the SLP or BBK shorties. If someone was very diligent on the installation job and used very high quality exhaust gaskets they could likely avoid the leak issues I had.
HellTeeOne, Did you run the catless y pipe from Mac? What header gasket would you recommend to prevent leakage? What did you notice with power if and when you went to LT's?
I have had the best luck with Percys header gaskets, the aluminum layered ones. That's what I'm currently running with my LTs. If I had known about them back when I had the shorties, they may have saved me some grief.
I don't have anything quantifiable from when I went from shorties to LTs, as I changed a bunch of other stuff at that same time as well. With any setup making under around 400rwhp, I would imagine the difference between the MACs and the LTs would be less than 10rwhp. At the time I was 'cam only', my tuner insisted that my shorty headers would be "working against me". When the car subsequently made well over 350rw when tuned, he changed his mind on that affair. I do remember the shorties being a night-and-day difference over stock manifolds with the stock engine.
It's been years since I've checked the MAC site.
I'll say I think the long tubes are a better choice....but just about anything will breathe better than the stock manifolds....and they are a choking point that must be opened up.
