Are GMPP crate engine weights correct?
Old Feb 22, 2015 | 08:13 PM
cardo0's Avatar
Default Are GMPP crate engine weights correct?
Im reading the 2014 catalog (pgs 64, 65) and finding good old sbc crate engines w/alum heads weight less than the all alum LS3 crate motors! But i seem find a lot numerical typo errors so dont know what to think. Now I need get the 2015 catalog ASAP.
But what i see now is the LS3's (3 variations) all weight 415lbs and the ZZ383 weights 410lbs! Turnkey ZZ5 = 410lbs. Odly the ZZ4 turkey is a fat 511lbs (cant explain that). Also the 7 liter LS7 weights 440lbs!
Is someone in the GMPP print room dyslectic?
Old Feb 22, 2015 | 09:33 PM
96capricemgr's Avatar
Probably differences in completeness.
Accessories, damper, flywheel etc.
Old Feb 23, 2015 | 08:23 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Old Feb 24, 2015 | 11:48 PM
cardo0's Avatar
Wow a 14lb oil pan. I never new carburetors weighed 12lbs.
Its frustrating as GMPP lists the "production-based" sbc at 181lbs but fails to provide any weights for LS3 alum blocks. The GEN I sbc blocks in alum weight in at 90 and 101lbs.
But u can see the LS3 crate motors are sold with exh manifolds where the GEN I sbc crates dont. That should acount for some weight gain on the LS motors.
I really think someone would have to weight the same car after swapping motors to find the true difference.
