Engine DONE, until I try starting it!
You are looking at a 385ci LT4
-Lingenfelter ported heads and intake
-24x Conversion
-Custom mounted and custom intercooled F1A
-LPP long tubes
-Custom Air Intake Box using Dodge Viper Air Cleaners
-Custom Strut Tower Brace
Custom Intake Box that I designed and made.
Now I just hope the combination works!
And yes the hood barely closes...
I would recommend doing the fuel line relocation and reroute the wires on the passenger side fender. Would clean it up even more than it already is.
The strut tower brace is easy to get off but you have to lift the front of the car to access 2 of the bolts on each side that hold the control arm/coilover mount in place. And the intake box just uses the 2 upper TB bolts in the front and the 2 fuel rail bolts in open slotted mounts in the rear (don't have to take the bolt out).
I will probably do more cleaning of the tower areas later...
I agree a fuel line relocate and passenger wheel well wire tuck would add to an already awesome engine bay.
I have to repaint them since there was some kind of contamination after cleaning them. Since they have to be repainted I am thinking of going with a flat clear coat over the same charcoal color. The other color option is Lime Green, same as the top color on the car (but if I went with that should I stick with gloss clear or go with flat clear coat?).
Any thoughts on the color of the 3 panels?
