LT1 Radiator - Oil cooler bypass plug
How are you guys plugging this port? I have a short hose with a brass plug I hit on the lathe to fit. It still leaks a bit once the system gets up to temp and the water pump really starts pushing a lot of water. JB Weld + plug? Ideally I'd like to just cap it or plug it, but there's not enough material to thread it safely without it splitting in my honest opinion. Ideas would be great fellas!
I'm confused, where does it attach on the pump? I have an upper and lower on mine that are connected. I had been suggest 2-part epoxy/radiator repair also to fill it in. I have the hot side of the turbo setup right up front so I'm trying to keep it as clean as possible.
Pull the tube out, then tap the hole and plug it. Or you could use a water pump from a Corvette (or a b-body) that does not use that port.
http://shbox.com/1/lt1_water_pumps.jpg
Man-Crush Warning
I run a cap from a auto store no issue.
