Cam for Daily driver
There are lots of good daily driver cams, but I'm not sure there's any out there that's going to make that kind of power under 6000 rpm to the wheels with stock heads, even through an M6/10 bolt combo.
You need long tube headers to hit your HP goals too.
Has CAI, airfoil, tb bypass, high flow bullet muffler, and its a six speed with original 10 bolt.
I have mac mid headers and catless y pipe thats going on if I get pointed towards a good cam. Solomon mail order tune would be next. I guess that 390flywheel hp equals about 330rw. I guess I would expect at least 375 flywheel hp miminum or it wouldn't be worth the effort.
https://ls1tech.com/forums/lt1-lt4-m...omp-502-a.html
The numbers in the graphs represent STD instead of SAE correction factors, but it gives you a decent idea of the power curve and numbers you can expect from it. I have this cam, and I can say first hand that you'd love it as a daily driver/street cam. I run GMPP 1.6 ratio rockers (basically factory LT4) and Comp Cams 987 valve springs with the cam.
The Comp Cams XFI grind (part # 07-466-8) is pretty much in the same ball park, but with a little more lift and on a 113 degree LSA.
There is some minor bucking on tip in when in a parking lot(lean stumble in MAF mode), but nothing troubling beyond that. Drives really well.
I have bigger plans for the car.....I want to add at least another 100hp, but the CC503 delivers good numbers on stock heads with the proper valvetrain, CAI, and exhaust parts.
On the old tune it made 294 whp on James' dyno and 332 whp on Lee Blankenship's dyno.
I'm sure a custom cam from Lloyd Elliot or Advance Induction would net more power, but ET's matter and not dyno numbers.
