How to hold the crank from turning in 1996 impala SS while the engine is in the car to tighten the bolts of the crank pulley and the center bolt of crank. I need to tighten these bolts. Need help.
Get one of the tools that's used to hold/turn a flywheel. It has a couple of "hooks" that grab the teeth of the flywheel, and you can either turn the flywheel, to access the bolts, or hold the flywheel, to tighten the bolts....
