Installing crankshaft seal
Old Aug 3, 2015 | 03:05 AM
Abdullah's Avatar
Default Installing crankshaft seal
how to remove the old crankshaft seal? and how to install the new one?
Old Aug 3, 2015 | 06:40 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
You should consider some factory service manuals. They pop up on eBay fairly regularly and are a great resource for anyone that does a lot their own automotive work.
Old Aug 3, 2015 | 07:08 AM
moehorsepower's Avatar
If you are asking how to remove the seal? I would just take it to a mechanic..
Old Aug 3, 2015 | 08:17 AM
93M6Formula's Avatar
When I have to pull a seal like that, I screw in a set of sheet metal screws and then pull on those. Or they make a seal puller but there's not a lot of room to swing it in there. Or just use a flat screw driver and a hammer to deform it until it comes out. Then just find a large socket or something the same size as the seal to drive it in.
Old Aug 3, 2015 | 09:48 AM
SS RRR's Avatar
Village Troll
Tap around the circumference of the seal until fully seated with this:
Old Aug 3, 2015 | 02:56 PM
ACE1252's Avatar
Which one, rear main or front?
Rear main will require removal of the transmission, clutch/torque converter, flywheel. Then you can pry it out on the outside with a flat blade screwdriver. There are places in the seal housing to put the screwdriver. You just need to be careful not to catch the crank with the screwdriver or you will have a leak problem if you scratch it.
For installation, I use a 4 in PVC pipe adapter. Lube the inner seal with a little oil, the put the seal on evenly all the way around by hand, then use the PVC pipe and hammer to tap evenly all the way around the seal until seated. It must go in evenly.
It may not hurt to buy a couple in case you screw one up(if this is your first seal install).
For the front crank seal, you will need to remove the timing cover. Then use the seal removal tool SS RRR posted. It will be tough coming out as I doubled over one of those tools replacing my timing cover seals a few years ago.
Get to Youtube and watch some people install one piece rear crankshaft seals and front cover seals.
If you need a digital copy of the factory service manuals, GaryDoug(I think this is from him...) has you covered.
https://www.mediafire.com/?40mfgeoe4ctti
Old Aug 3, 2015 | 04:07 PM
When I purchased my rear seal, it came with a installation tool...
Old Aug 3, 2015 | 11:01 PM
Abdullah's Avatar
I meant the front crankshaft seal.
Old Aug 4, 2015 | 03:34 PM
SS RRR's Avatar
Village Troll
Old Aug 4, 2015 | 05:30 PM
Abdullah's Avatar
OK SS RRR, thanks.
Old Aug 4, 2015 | 06:26 PM
Badazz 97 TA's Avatar
When I had to do mine the first time all I did was remove the hub and gently pry the seal off with a screwdriver. It seemed like the OEM stock style is made of a softer material that makes it super easy to install and remove unlike the metal style that comes in a felpro kit. That was my experience.
I don't see why you have to remove the timing cover for that like posted above.
Old Aug 4, 2015 | 08:26 PM
ACE1252's Avatar
There may be other ways to do it, but I think removing the timing cover is the safest.
You can also use a punch to put a small hole(or drill the hole) in the seal edge. Next use a slide hammer with a sheet metal screw on the end to turn into the hole you just put in the seal. Then slide hammer it out. We used to do that to remove them from gear boxes. However it does leave a small amount of metal shavings if you drill it.
I, myself, would not do anything to risk scratching the crank.
Old Aug 6, 2015 | 04:43 PM
SS RRR's Avatar
Village Troll
No. Completely unnecessary for such a simple job. It's amazing how easy things like this are with the correct tools.
Old Aug 7, 2015 | 05:38 AM
Abdullah's Avatar
[/img]
where to buy the above tool from? what is the website?
thanks.
Old Aug 7, 2015 | 07:05 AM
SS RRR's Avatar
Village Troll
if you can get stuff shipped to you from amazon:
http://www.amazon.com/gp/aw/d/B0002SRCKG/ref=mp_s_a_1_1?qid=1438949027&sr=8-1&pi=AC_SX200_QL40&keywords=seal+puller&dpPl=1&dpI D=31q8HS6e6IL&ref=plSrch
or just google 'seal puller'.
Old Aug 7, 2015 | 07:20 AM
Abdullah's Avatar
Thanks.
Old Aug 7, 2015 | 10:21 AM
shbox's Avatar
Just pry the thing out with a screwdriver, already. The seal puller is hard to use with the crank nose sticking out in the middle.
Old Aug 7, 2015 | 11:22 AM
BALLSS's Avatar
OP
if you are having a problem getting a seal puller in your location....just use a good size screw driver and a small piece of wood or something to act as a fulcrum and carefully pry up the seal with the tip of the screw driver. Just work around the inner edge of the seal. be careful not to catch the edge of the timing cover itself, just seal. The seal should lift out quite easily
to install just use a soft blow hammer like what SSR posted and tap gently in a circular motion around edge of seal until it is set flush in timing cover
pretty straight forward job.
Same procedure for Opti seal if you are doing that. The WP drive seal does want to be installed with some form of "sleeve" that fits over the WP drive spline. There is a specific tool for that but you can use the appropriate size long socket or even the coupler that joins the wp drive spline to wp spline. Point is you do not want to fold the inner lip over when installing the wp drive seal (assuming you are replacing all 3 Timing Cover seals)
FYI the crank seal you can grease the inner lip, the opti & wp seals install "dry" as they are PTFE seals
The FelPro TC gasket/seal kit has all the seals and gaskets you will need for around $12
Old Aug 7, 2015 | 12:28 PM
roninsonic's Avatar
You can't always just pry them out. Some people (like myself) like to coat the OD of the seal with loktite when they install it. It acts as a lube when it's wet and seals up good when dry.
Downside is that it's a bitch to get it out later
The correct way is to pull the cover, anyway. That way you can align the front cover perfectly using the seal.
Old Aug 7, 2015 | 02:33 PM
Abdullah's Avatar
I will try your way tomorrow ******, the hammer and the screwdriver if God will.
