Help with pulley
Old Aug 6, 2015 | 06:48 PM
Viper's Avatar
Default Help with pulley
Ok,so I'm taking off the main hub to replace seals due to an oil leak. I bought the car in May and have zero history. 97 TA LT1.
As you can see in the pics I got the main pulley off but the hub behind it is not what I was expecting for a LT1.
Can anyone help explain what it is and possibly how to remove? Obviously there is a bolt in the center but I was expecting the 3 winged hub typical of the LT1.
Thanks!
Attached Thumbnails Help with pulley-web-pic1.jpg   Help with pulley-web-pic2.jpg
Old Aug 6, 2015 | 10:58 PM
ACE1252's Avatar
That's not stock, but I'm guessing it should come off like a stock hub. Remove the center bolt and use a puller on it as you would a stock hub.
Old Aug 7, 2015 | 05:31 AM
Viper's Avatar
Thanks, I was hoping someone would recognize it (brand etc.). I have a March UD pulley going on.
Old Aug 7, 2015 | 10:24 AM
shbox's Avatar
Guessing that is some sort of underdrive already. UDs don't do much for LT1s anyway.
Old Aug 7, 2015 | 10:27 AM
Viper's Avatar
Interesting - why would you still need the stock dampener put on the end? And hey after being a member on here since 2001 a big THANKS shbox to all the diagrams you have provided. I have had 3 LS1's but this is the first LT1 I've worked on extensively and your work has saved me a ton of work the last 3 months!
Old Aug 7, 2015 | 12:32 PM
lt1-xjs's Avatar
That pulley should also slide off to expose the hub.
Old Aug 7, 2015 | 04:05 PM
shbox's Avatar
You still need the dampener, because the UD pulleys don't always have one.
Old Aug 9, 2015 | 08:27 AM
SS RRR's Avatar
Village Troll
You don't need to take the UD pulley off to get the hub off. If you want to take it off and depending on how long the UD pulley has been on the hub it can be a chore. You can try to grab it with both hands and wiggle it back/forth if there is any play in it. Eventually it will come off. If there is no play in it you will have to take a pry bar and hammer to it. This will most likely damage it. I had my engine on a stand, hammered it and when it finally broke loose, shot about six feet away from the stand.
Old Aug 9, 2015 | 08:32 AM
Viper's Avatar
Managed to slide it right off, it appears to be an ASP underdrive pulley. Got the hub off too last night. Scary, the hub bolt was loose. I'm replacing all seals but would a loose hub bolt let oil out too? This all started with oil dripping along the cps.
Old Aug 9, 2015 | 10:03 AM
SS RRR's Avatar
Village Troll
No. Oil leaking from a seal will sling oil everywhere as well as drip from the lowest point. If oil is only dripping off the sensor then it may be leaking from only the sensor. I think it has a an o-ring gasket?
Old Aug 9, 2015 | 11:08 AM
Viper's Avatar
I bought a replacement to be safe.
Old Aug 9, 2015 | 02:30 PM
Viper's Avatar
OK, new issue. The timing cover looks beat up on the inside. Where can I get a replacement? All I'm finding is ebay for $200-$300.
Old Aug 9, 2015 | 03:06 PM
SS RRR's Avatar
Village Troll
How is it beat up? You need to find out why before simply replacing the cover. Take a pic and post it up.
Old Aug 9, 2015 | 04:08 PM
Viper's Avatar
Here u go - lips look beat up
Attached Thumbnails Help with pulley-20150809_162934_resized.jpg   Help with pulley-20150809_162940_resized.jpg   Help with pulley-20150809_163010_resized.jpg   Help with pulley-20150809_162945_resized.jpg
Old Aug 9, 2015 | 04:29 PM
SS RRR's Avatar
Village Troll
I don't think that will matter.
Old Aug 9, 2015 | 10:22 PM
shbox's Avatar
Just looks dirty to me.
Old Aug 10, 2015 | 07:04 AM
SS RRR's Avatar
Village Troll
Get some mineral spirits, nylon brush and clean it? Thing is, if your timing cover has baked on oil like that, so does the rest of the inside of your engine.
Old Aug 10, 2015 | 07:48 AM
Viper's Avatar
Yep, I'm guessing possibly your right. The only history I have is he did heads and gm hotcam. It's not the varnish on the timing cover I'm trying to show in the pics it is the bent lips on the crank and opti.
Old Aug 10, 2015 | 10:06 AM
SS RRR's Avatar
Village Troll
Understood, but even so I do not think it should be a problem. If they interfere with the OD of the seal then you can sand them down.
Old Aug 10, 2015 | 10:55 AM
shbox's Avatar
I see what you are talking about, now and agree with what SS RRR said above.
