oil filter relocation kit
Old Aug 22, 2015 | 01:00 AM
97REaper's Avatar
Default oil filter relocation kit
I need a relocation kit and need help deciding which works with lt1s. Part numbers would be helpful. Thanks
Old Aug 22, 2015 | 06:46 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Canton makes a very nice piece that goes in place of the oil filter. It rotates to point in any direction to best route the hoses around them hot headers.
I believe it's this one but confirm the filter thread size on your own.
https://www.cantonracingproducts.com...-ADAPTER-18MM/
And the remote filter mount should be for the original larger filter size for a PF25/35. Bigger filters = better flow.
Old Aug 22, 2015 | 09:18 PM
96LT1Z's Avatar
If you don't like that one, I believe any sbc one should work
Old Aug 24, 2015 | 01:23 AM
97REaper's Avatar
Do I need to make my own oil lines?
Old Aug 24, 2015 | 06:51 AM
Paul Bell's Avatar
There are kits available with everything needed, but you'll find none of them will be exactly perfect for your needs.
T&D makes a lot of kits. Make sure the hose is at least 1/2 inch and the cooler is the stacked plate type, not tubes in fins.
Old Aug 24, 2015 | 07:13 AM
Shownomercy's Avatar
Man-Crush Warning
I would, use quality braided SS, spewing hot oil on headers will make for a nice quick BBQ of engine and car.
Old Aug 25, 2015 | 02:56 AM
97REaper's Avatar
I deleted the oil cooler adapter. So -8 AN SS would work? What else do I need to work with the canton setup?
Old Aug 25, 2015 | 06:08 AM
Man-Crush Warning
I would say -10an at minimum
Old Aug 29, 2015 | 02:44 AM
97REaper's Avatar
I was told this kit is what works with lt1s now im confused. Hahaha http://m.summitracing.com/parts/ctr-22-592 do these kits come with both adapters one for the block and one for the filter?
Old Aug 29, 2015 | 09:34 AM
Paul Bell's Avatar
If you wanna keep things simple, have a look at this kit:
http://www.summitracing.com/oh/parts...t/model/camaro
Old Aug 29, 2015 | 09:40 AM
Paul Bell's Avatar
I see that in post #5 I mentioned a plate cooler. Sorry, you never mentioned a cooler, just a oil filter relocation kit.
If you were to add to your oil filter relocation kit an oil cooler (which would be easy once you have lines coming off the engine) make sure it's the better design of cooler with stacked plates.
Old Aug 31, 2015 | 02:02 AM
97REaper's Avatar
Your link isn't working for me whats the part number thanks
Old Aug 31, 2015 | 08:06 AM
Paul Bell's Avatar
The link works for me....
You can go to Summit Racing and just search for 1122.
