95 trans am keeps blowing fusible link e help!
Old Dec 23, 2015 | 05:29 AM
Treachery's Avatar
Default 95 trans am keeps blowing fusible link e help!
95 ta lt1 t56 was running fine when cooling fans decided not to come on so I tried the jumping pin 5 and 6 of the DLC to make the fans kick apparently this shorted something out and now nothing works while key is in the on position no dash no crank no radio, I tried changing column out with a new ignition switch , which did not help, my test process is to take test leads with a blade fuse between them. Any ideas
Old Dec 23, 2015 | 02:51 PM
Treachery's Avatar
Default update
ive since tried unplugging fans and still blows 10 amp fuse, tried hooking up another fusible link thatt ended with lots of smoke from new link and from ignition switch, tried a 20 amp fuse and i hear a sizzle sound (dont wanna do that anymore) i need help please
Old Dec 23, 2015 | 02:58 PM
Treachery's Avatar
shbox help me out
Old Dec 24, 2015 | 07:24 PM
Treachery's Avatar
update ive traced red wire back to column and its fine upon searching the ignition switch wires there is a double pink wire that is grounded could this be my problem
Old Dec 25, 2015 | 09:10 AM
Treachery's Avatar
upon tracing the pink wire down i found were a sheet metal screw had cut the insulation so i fixed that and the wire is still grounded
Old Dec 25, 2015 | 11:03 AM
shbox's Avatar
Use the schematics on my website. Pink wires are not supposed to be grounded. Since you put a larger fuse in (super bad idea), you could have damaged wiring anywhere.
Old Dec 25, 2015 | 01:09 PM
Treachery's Avatar
Default thanks
yeah i have been using your site it has loads of info, what would be an equivalent fuse for test purposes? i read that a 1.0 mm fusible link was equivalent to a 22 amp so i thought that was ok but your right super bad idea!!
Old Dec 25, 2015 | 02:23 PM
shbox's Avatar
IDK about a comparable fuse size, but you should use your meter to search for a ground on the link in question, pulling fuses that are served by that link to narrow it down.
Old Dec 25, 2015 | 10:24 PM
Treachery's Avatar
Default thanks for the help
thats what ive been doing since i realized i had a problem, strange thing is there is not a single fuse blown, ill keep you posted on what i find out, all this over a inner fender screw
Old Dec 27, 2015 | 10:24 AM
Treachery's Avatar
ok ive got everywhere it need to be to get a crank, the orange wire from ignition switch to underhood fuse box seems to be shot i would like to hear it crank tho, can i run a test at this point, and how hard is it to pull the complete wiring harness? not the engine harness the one that goes to the fuse boxes
Old Dec 27, 2015 | 12:14 PM
Cajun ELESS-ONE's Avatar
https://ls1tech.com/forums/general-m...95-camaro.html
hey man. i had an issue with my fans not working and the 10amp fan fuse kept popping. i traced it to an o2 sensor wire grounding out on my header. i wasnt blowing any fuseable links, but it could help
Old Dec 27, 2015 | 01:01 PM
Treachery's Avatar
i found the cause , it was one of the sheet metal screws that hold the little plastic inner fender in cut the pink wire of the ignition switch right below the fuse box , the problem now is all the damage that it has caused to the wiring, i have since got it to run by bypass the hot wire to the ignition and running my own, i hate extra wiring tho, the issue im stuck on now is the orange wire off the ignition that goes to the under hood fuse box apparently its fried too and i cant find were to tie into it at as it splits into 3 after the ignition switch
Old Dec 27, 2015 | 05:34 PM
Treachery's Avatar
ok shbox ive got down to where all i need to fix is in the underhood fuse box fuses for fans/actr and abs ign are grounded on both sides ive cut the bad wire out so why would they still show grounded on both fuses?
Old Dec 29, 2015 | 10:04 PM
Treachery's Avatar
its the fan side is the cause of the ground fuse 6 the brown wire of the c100 connector is grounded out in the harness between the shock tower plug and the interior kick panel plug, ive looked and untaped for hours would you see a problem with splicing a good wire between the 2 plugs i do not see on any schematics that it runs anywhere else
Old Dec 30, 2015 | 10:45 AM
shbox's Avatar
Isolate (unplug) your wires on both ends for testing for grounds. That way any ground through a device that is connected is not interfering with the test.
Old Dec 30, 2015 | 03:05 PM
Treachery's Avatar
the brown wire is grounded on both sides of plug interior and the one on top of strut i traced it a little farther and im getting into the engine harness, where does it go?
Old Dec 31, 2015 | 05:06 AM
Treachery's Avatar
I unplugged every plug on the car it finally quit showing ground when I unbolted the grounds from the coil
Old Jan 4, 2016 | 05:18 AM
Treachery's Avatar
Ok so the thing is back running I had to get a donor engine wiring harness never could locate short, ended up the cause was a sheet metal screw holding in the inner fender right below fuse box and it also fried the hot wire going to the ignition,
Also I have a question I'm new to this car but I seemed like the rear hatch button worked before when key was in the off position now it only works with key in run is this correct?
