A Little Dyno Time Today
And another factor is fuel economy of a small engine vs a large engine is the rpm they have to run at cruise, the most efficient rpm is around 1600-2000rpm, below that a lot of heat energy in a cylinder is transferred to the coolant before it can be used for rotational energy, above that it gets pissed out the exhaust. The bigger engines that can pull at 1600-2000rpm on the highway are in the most efficient range for an internal combustion engine, and is a reason manufacturers like 190-200 degree T stats but we as performance enthusiasts like 160 degree stats, but you bleed too much heat to coolant for efficiency while cruising.
You bring up an interesting point about Temp again. I'll take a step back and re-analyze the temp issue. We want air as hot as possible in the largest mass possible for maximum power(hotter air contains more energy, however little), except that this is not good against fuel quality and creates problems (explosions). There is a trade off at play here. For an economy vehicle, the exhaust should be allowed to get as hot as it can (without hurting parts) since the dynamic (cruise) compression should be low (no fuel quality issue) we can allow the EGT and other temps to rise for better engine efficiency. The more Temp rise we can trap in the exhaust system and engine, the better our economy should become (until fuel Q issue crops up and pressure begins to spike). We also want to minimize EGT coming out of the valve, to get the most of our fuel. Ideal EGT would be less than IAT, to prove we extracted more energy from the fuel. Performance is similar except that now fuel quality is a bigger issue. We want to dump the temp rise when it gets above a certain point to protect the engine (against fuel quality issue) just like when cruising, however, we also want the mass increasing effect of a low intake temp which does not matter during a highway cruise (no need to max VE and air mass together while cruising). We run the IAT down as low as you can go, and again allow the EGT to get as high as it wants until a set point, at which you take measures to control it. The main difference is that when extracting maximum performance, you remove extra temperature for safety, thus the idea behind 160*F thermostats and water injection and intercooling and all similar ideas. This is safety against the fuel quality, an important correlation to keep intact, since as colder air becomes more dense, there are more air molecules, the engine makes more power, and what is it that kills stock piston LT1 engines? Apparently, it is making too much power (regardless of temp they fail around 400-450hp right?). So there is some low temperature which will provide enough air molecules to kill an LT1 piston, around the same number of air molecules that would kill it in a boosted application I would have to guess. Temperature is just another way to adjust molecules/area the way boost pressure does, it can be used in a similar way. This is why I am emphasizing control of temperature and pressure in the engine. Heat shields, blankets, wraps, coatings, meth/water, intercooler, create duct, extra large fans, aux cooling, they all have places in performance application for control.
My argument against low coolant temps is only on engines which have trouble getting the oil temperature up in a daily driver application. Sometimes you put a 160*F thermostat and now the oil takes twice as long to hit 200*F if you are just driving the car around town and idling. A properly tuned configuration (more than just the computer's tune, the way the engine is dressed and blanketed is part of the "tune") will not throw alot of temp rise into the coolant (we want to minimize energy lost to the coolant and use as much of the fuel as possible to drive the piston) and together low oil temps and daily drivers is a bad combination for the engine, as it has been shown to increase engine wear and tear. There have been plenty of studies of low fluid temps creating longevity issues that I do not feel the need to elaborate.
Oh wait I get it. What you're saying is, that if I built a high compression turbo motor using a stock LT1 all would be fine if I run Meth injection for $27.96/gal, 110 Octane (bad for power BTW) for $11.93/gal, and have a top notch intercooler. AND if I install a turbine "disable" future (like a clutch right?), I'll GAIN FE? Yup, makes sense now that you put it that way......
Brake Mean Effective Pressure, is just that; how much mean effective pressure would it take within that engine to produce the output it does. Mean Effective Pressure= pressure in excess, averaged through out all cycles of an internal combustion engine, to produce usable power to perform other tasks.
Cruise has little to do with actual speed and more to do with maintaining a speed. You'll use less fuel per mile maintaining 120mph than you would doing 2mph then stopping, 10mph, stopping, 8 mph, stopping, 45mph, stopping, 25 mph, stopping....... I think you get the point. Well I hope you do cause I'm not going to keep typing all that stop and go traffic none sense and how it results in accelerating, decelerating, accelerating, etc, etc.
What speed the vehicle is most efficient at while cruising is irrelevant.
Why don't you run higher compression ratio on the Turbo?..... Is it because there's a Turbo? And you can't run high compression ratio's (read: high expansion ratios, read: higher efficiency????) unless you run fuel that costs 10x as much as the **** at the pump?
You can't guarantee anything. Name one production car that added a Turbo WITHOUT making the engine smaller that GAINED MPG. It's never happened. Think, listen to what is being told to you, think some more, you may realize why.......
This is all you needed to say, but noooooo.......
In other words the limitations of the fuel being used is exceed BECAUSE of the Turbo. You can't magically blame it on the ACTUAL material being used to do the work! The FUEL IS what moves the car, the FUEL is what does ALL of it. Not the Turbo, the fuel. The fuel is more important than the turbo.
This isn't pretend land. I'm not playing in pretend land.
Basically this is what you said " if we ignore reality and physics and only apply what I think will happen, what do you think will happen?"
To be more clear here. 14.7:1 is 14.7:1 regardless of air density, temp, or whatever else because 14.7:1 is by weight (mass).
Changing Air density is increasing Mass. VE tables are done in percentage, but they are used to calculate MASS of airflow. So if you crammed 2 bar of air at any RPM VE would be 200% (theoretical), but it's actual volume is not 200%, it's still at 100% (or less), it's MASS is at 200%. But, it's MASS that is needed because that is what the fuel is calculated at and from, mass. Mass doesn't change, it's always constant. Volume and density may change, but mass is constant.
No wait, I'm confused. Are you saying the VE tables do or don't change?
Semi logical?
Semi logical?
I'm trying to picture a 2bar VE table with VE under 100% for the second bar (although that would make sense). I'll have to look at the tables to see this I guess. Maybe KingTal0n can't post up one of his hundreds of tunes showing this......
