A Little Dyno Time Today
Each box contains an injector pulsewidth. For this engine I disabled the boost compensation map (for the most part, it might still be adding 2% up top) This is from a 2jz-gte I tuned. It shows what you want, a 1-bar of boost pressure without a 100% VE increase to injector on-time due to an OEM camshaft restricting VE primarily. VE does not always correlate torque (you cannot always say peak VE = peak torque), since ignition timing can ruin torque output even when VE is good or getting better.
And peak VE and peak TQ are directly tied. The relationship between the two are tied because the more air you take in the more power you can make (force over time and distance), and since power is relative to TQ (force) at RPM (time and distance) at the point the engine is taking in the highest amount of air it can, it will always peak TQ there too. It will not necessarily peak HP there because HP is a result of TQ AND RPM. TQ is a result of air flow.
Of course, if someone tuned the car wrong it could mess up the relationship between peak TQ and Peak VE. But I doubt that as peak TQ is a result of peak air flow. If someone messed up the timing or AFR's in the Peak VE range VE would be reduced (and therefore TQ), that would result in peak Torque and peak VE both being moved, together. In any case, I'm talking about optimally tuned engines for their given design and purpose.
The map does communicate engine VE by comparing pulsewidths between known ranges, like from from 0 to 15 psi. It moves from 3.2 to 4.8. Yes at 3.2 it was leaner than 11:1, and maybe there is 2% boost comp, and maybe another 1.5% from the TPS, and maybe .05% from my CTS, see how many variables start to play a role? But we can still make an observation about the move from 3.2 to 4.8, for example I can tell you for sure that VE did not double at 15psi of boost. This is information you will know when tuning YOUR engine, not mine, I am not assuming you know what engine this is for, I am not saying this is a VE graph, I am saying that if you DID have an engine to tune, and you DID have this kind of fuel map, these values would communicate engine VE to you as you run the engine and gain intuition about its behaviors, by comparing engine output and boost pressure with fuel use. As another example I know that if the engine receives a head/cam I will immediately need to raise the values inside those cells that say 4.8 to around 2(3.2) or 6.5 for starters because NOW I would be thinking about 200%VE, and that is the place where it is bound to show up.
http://www.epi-eng.com/piston_engine...efficiency.htm
Greg Banish, in one of his books, closely compares the VE with the torque curve as well.
Do you build a VE table from a torque curve? No. However that does not mean that the two don't correlate.
There are many, many LT1 cars out there with factory bottom ends making in excess of 400rwhp with ported heads/cam setups and lasting tens of thousands of daily driven hard miles. There are several on this forum currently and have been many more over the years.
You are not going to find many at all doing the same thing with the stock engine and a supercharger or turbocharger, and you'll likely find NONE that have lasted more than just a few thousand miles under boost.
11:1 was the lean point?! Holy ***** batman, how do you not see how much richer Turbo runs than NA? My RICH point in PE mode is 11.9:1, your leanest point is 8.6% richer than my richest point. And my richest point needs leaned out by 0.5-1:1.
- Lock the PCM into speed density
- Set all fueling targets to Lambda 1
- Using a wideband to record Lambda data, setup a histogram plotted against the VE table to display Lambda error.
- Run the engine in steady state on a load bearing dyno(locking the engine rpm and thus varying throttle..which moves you through the MAP ranges), record data for the fueling error in each of the VE cells.
- Correct the VE table in each cell for the displayed fueling error.
- Lather, rinse, repeat until you are within 3% error, then move to the next RPM point.
It was very eye opening for me to see this done. I appreciate the engineering angle he takes with tuning.
Part of Banish's VE building process can be seen at 10:44-11:44 with the Z06 on the dyno.
I think this link will take you straight to that point.
Calibrated Success GM Tuning Beginners Guide (long demo) - YouTube
I have not got my Z28 on the dyno for "me" tuning it yet. I started to last year, by brushing up on all the stuff I've learned but life happened and I had to put those plans on hold. I'm picking back up on that project very soon though....I'll be logging my LT1's VE error with this....
http://www.palmerperformance.com/pro...shots/maps.png
I've been "blogging" over the years about my tuning journey here...and I've made mistakes along the way, but it's been a fun learning experience.....with plenty more journey to go.
http://www.camaroz28.com/forums/comp...ts-lt1-770192/
When I did my VE tables, I locked out BLM locker and PE modes were set to zero. Then I reset all my BLM's. I'd drive for an hour, look at my log and adjust the VE tables based on BLMs in each cell, load the new tune, reset BLMs again and repeat. I'd smooth out the transitions between cells to after every adjustment. This took me a loooong time to do. Months to get it all dialed in.
I don't have that kind of access to a Dyno to load up each cell so I did what I could with what I have. Once I dialed in all my BLM cells, I took the car to a dyno and used a wideband to dial in PE modes. My PE tables are a bit skewed because I can't adjust my VE tables over 100%, to make up for that I used the PE tables to dial in the AFR target at WOT (I'm only at WOT when over 100% VE).
Now I wont go MAF mode because it's not calibrated for my engine any more (CAI, Cam,etc.). Next time I'm on the Dyno I'll have the PE Tables done in SD mode, then engage MAF mode and calibrate the MAF according to the Wideband. That should give me a very reliable tune.
This works out o.k. for now though. I still have a little bit of tweaking to do on my PE tables (lean it out a bit). But that can wait until after I get a 4" exhaust and my TB and Intake Done.
http://www.sciencedirect.com/science...59431115009849
Another article with test engines and output graphs for proof:
http://www.autospeed.com/cms/article...onomy&A=109931
I grow tired of this. Everywhere you look, you find that turbochargers may improve economy, and they are working on advances to it i.e. steam turbocharging and direct injection techs to go along with it. I don't find a single paper saying otherwise, just you.
From the article you shared.....
"Unfortunately for this comparison, the two engines aren’t available in Skodas with the same transmissions – the 2.0 FSI has a six-speed auto and the turbo 2.0 FSI a six-speed manual" They also fail to mention actual test vehicles used. I find that interesting and makes their credibility questionable at best, especially after what I found below.....
Not helping your argument. With the same transmission, it took a smaller boosted engine to beat the larger NA in fuel economy...... Hmmmm.....
A little more research shows that the FSI 2.0 (NA) get's 7.4L/100kM (31.8 US MPG) with A-95 fuel vs 7.9L/100kM (29.8 US MPG)for the TFSI (Turbo) 2.0 with A-98 (yes a higher rated octane fuel) in the same vehicle.
So officially rated, and not by someone writing an article with an agenda, the 2.0 NA gets better MPG than the Turbo variant, even with a different transmission and lower grade fuel.
Should I ignore that too?
Ty McBride
Team Leader/Owner
McBride Motorsports
Ps...any companies out there I might not know about making quality Door Panel Inserts? Mine are fine as is, just wanting to upgrade my interior a bit. Thank you
If you spin an engine with an electric motor, there will be some VE, not the same exact VE as when it was running, but we get this equation:
CID X rpm / 3456 = CFM
This equation implies CFM is a function of CID and RPM, not if the engine is running or not.
therefore, you can have a VE from 0 to 100% without a running engine (0 torque), the two share a domain function but are not directly correlated. Tuners might talk about them together (I often do) but specifically, they are independant functions. The word correlate is confusing because everything is correlated, mice and atoms, sun and gravity.
I still have all the pics.
I never posted a theory, a theory needs graphs and data points to be accepted backed by years of supplementary research. I only said that if we have X number of air molecules, the piston will fail, whether it was there due to low temperature or forced induction at higher temperature, or visca versa, high temp on a natural aspirated engine, low temp on a forced induction engine. The high temp is only an issue when fuel quality is poor, whether forced inducted or not, resulting in a damaging pressure wave which fragments the piston. There is more than one way to kill a piston, we can use race fuel in a naturally aspirated engine and still ruin a piston.
If VE was purely a function of engine spinning it would get higher with higher RPM. It doesn't do that.
Peak VE dude, we're talking about peak VE. What the hell do you think I mean? I'm talking about a single 4 stroke event that has the highest Airflow during those 4 strokes compared to any other.
Now, as to a function on a running engine of VE, here is a function of VE:
VE = (CFM * 3456) / (CID * RPM)
As you can see, RPM must be > 0 for there to be engine VE. Therefore, engine VE is a function of a spinning engine. I politely recommend more math courses.
You are trying to shift around the subjects after being called on the carpet for such a silly statement. You write a book on what could be said in less than a paragraph trying to look smart, but instead it comes off as making you look desperate.
There is no shame in saying "Oops, I made a mistake. My bad." I've done it more times than I can count....and I do it not just to remain credible, but because it's the right thing to do.
So do yourself a favor and stop trying so hard to make yourself look right all the time, because you are not. Now, learn to deal with it in the right way other than trying to bait and switch the topics.
I built a twin turbo V8 setup in my backyard when I was 17 years old for less than $500 after building a forged engine and 700R4 for it. PM me for pics and details (anyone). This is the old site http://www.geocities.ws/kingtaling/turbo.html
You can't assume people know "what you mean". Be very specific; if you mean airflow per unit time, then say it. If you meant peak cylinder fill, then say it. Saying "airflow" arbitrarily is a unit-less, description less, a flawed expression. Also, during an exhaust stroke, there is potential to flow more air through the cylinder than during the intake stroke.
It does seem the only one oblivious to what I'm saying here is you....
Sounds like the only one here needing to gain some knowledge is you. May I suggest basic physics as a starting point? Follow that with some reading comprehension..... No, flip that. Reading comprehension first, then basic physics.
stay frosty, watch for tard driversTy McBride
Team Leader/Owner
McBride Motorspors
