Torqhead 24x Link PCM conversion
Old Feb 6, 2017 | 01:19 PM
  #61
KW Baraka's Avatar
Originally Posted by smitty2919
OP, can you chime in on the progress/updates? Kinda left us high and dry.
You might want to send him a PM.....at least that will alert him to your question. As it is, there's no telling when he'll come on the forum again or if he'll come to this thread to see your question.
Now.....that having been said, my TorqHead goes on my Impalaalong with a dyno-tune THIS week!
I'll let you know how it turns out!!
KW
Old Feb 6, 2017 | 01:27 PM
  #62
smitty2919's Avatar
Sounds good. I'm just wanting some feedback from people with this that have had this installed for a little while of DD use.
Old Feb 6, 2017 | 02:08 PM
  #63
KW Baraka's Avatar
Well.....my car won't be a daily driver (398ci solid roller), but I'll be driving and racing it enough over the next 6 months to have a real good idea how it acts.
My installer/tuner just did a TorqHead on another Impala (week before last) and he's VERY impressed with how it turned out.....install/tune/drivability were all easier/better than he'd anticipated before the kit arrived. He was also impressed with the components in the kit.
More info can be found via TorqHead's wed site, and their Face Book page --> https://www.facebook.com/pages/TorqH...23802061195083
KW
Old Feb 6, 2017 | 05:57 PM
  #64
smitty2919's Avatar
Sounds good. Reliability is big for me. I have a 96/97 timing cover already so I can go EFI Conn 24X route if needed or go with the TH setup.
Time will tell lol
Old Feb 7, 2017 | 12:08 PM
  #65
KW Baraka's Avatar
Time will tell lol
The bonus with TorqHead is that you can get EVERYTHING you need in one shot.
Also, you can have items deleted from your kit (with a credit on the price) if you already have matching parts. Me? I already had a set of NIB coils, so that saved me a few bills.
Additionally, the TorqHead supplied ECU comes with a base tune; so you'll be able to drive the car until you can arrange for something that'll better match your setup.
From a reliability standpoint.....I can't see where this would be less reliable than the EFI.
KW
Old Oct 8, 2017 | 07:03 PM
  #66
Alex-chevy's Avatar
Originally Posted by Chopstix
Took delivery of my Torqhead 24x Link Essentials kit today..all I can say is Wow, very impressed with the components.
The Essential kit ships with the following:
24xLink Sensing unit with adjustable crank sensor mount
Crank hub Assy wih 24x External Reluctor
24xLink PCM (Gen 3 411' PCM, plug and play for LTx Engines). Comes with C3 Add-on Harness.
AC Delco OEM 24x Crank Sensor
AC Delco OEM 1x Cam Sensor
Installation Instructions
OBD2 Port (Supplied if choosing '94-95' Only)
Water pump gaskets
I added the Torqhead coil brackets for a cleaner installation.
I will be supplying:
Ignition Coils
Spark plug wires
An Engine Tune
Please visit torqhead.com for more details.
Can someone please tell me how to tune this system or who to take it to. I've been emailing places and there anwser is..." We only tune ls1s". I say "I know....it is an LS1 computer, but they don't bother reading about the Torqhead system!!!!. What did you all do? Any good place in Virginia? Do I get a lab top and try to tune myself?
Thank you!!
Old Oct 8, 2017 | 08:02 PM
  #67
96lt1m6's Avatar
Most tuners freak when they hear the LT1 name. Unless you are getting a dyno tune they try to cheat by using a file already downloaded with a similar combo. An engine is nothing but an air pump(fuel, air, spark) so the experienced tuner can work those parameters.
Old Oct 8, 2017 | 08:59 PM
  #68
Alex-chevy's Avatar
Awesome, so they should be able to tune it. But make sure they do a Dyno tune correct?
Thank you
Old Oct 8, 2017 | 09:16 PM
  #69
96lt1m6's Avatar
Thats exactly what i would do if i were in your position. I have a slight edge cause my tuner lives by me and is down to tune on the fly. As soon as i get my Tqhead system together he is down to tune.
Old Oct 9, 2017 | 06:59 AM
  #70
smitty2919's Avatar
Go to the shop with reference material in hand and explain to them what you did. Yes it's a LS ignition system, but it's not a LS motor. The approach will be different to tune a LS vs an LT.
The base tune from TH will get it close to run and drive it on the dyno but by no means would I drive it far distances. Install it, make sure the car isles/runs then bring it to the shop. Also to avoid downtime on the dyno, see if you can plug a code reader into the OBDII port. My car would run and drive fine but I forgot to switch the one wire in the back of my OBD1.5 port for my tuners laptop to connect. 20min later all was well but the tuner is a friend of mine doing it after hours so it wasn't an issue.
Old Oct 9, 2017 | 08:08 AM
  #71
ringmaster72's Avatar
Where in VA are you?
Thank you!!
Old Oct 9, 2017 | 12:30 PM
  #72
KW Baraka's Avatar
Thank you
Make sure they do a street tune, too. On the dyno is cool, too.....but a dyno does not replicate street driving conditions.
And yes.....if a shop can tune a LS computer, then they should NOT have a problem with tuning the TorqHead kit.
KW
Old Oct 12, 2017 | 07:32 AM
  #73
moehorsepower's Avatar
All they have to do is tune it as an LT, but most see the LS and use LS parameters, this is very low timing compared to an LT, this is where some get confused,
Old Nov 21, 2017 | 02:32 PM
  #74
Alex-chevy's Avatar
Default Awesome!!
Originally Posted by 9t4zee28
Here is mine in its current state...
I
Did you custom make the ignition coil brackets? They look nice! If you did not make them, did they come with the kit?
Old Nov 22, 2017 | 10:04 PM
  #75
KW Baraka's Avatar
I
That's the TorqHead Kit..... http://www.torqhead.com/index.html
KW
Old Nov 23, 2017 | 09:18 PM
  #76
Alex-chevy's Avatar
KW
Thx...
Old Dec 5, 2017 | 11:22 AM
  #77
Alex-chevy's Avatar
Sorry for delay. Richmond VA.
Old Dec 5, 2017 | 06:07 PM
  #78
Wheel Stander's Avatar
Has anyone gotten any feedback on when Torq Head's 24x system will be available for 92 and 93 Vettes that run the outdated OBD-I?
Old Dec 6, 2017 | 10:56 AM
  #79
pantera_efi's Avatar
Default LT-1 Front Cover with CS location
Hi WS, I manufacture a OPTI that has the 24xe/58x/360 pulse train pattern. (your choice)
I manufacture a 24 OR 58x tooth TW that fits UNDER the late LT-1 Front cover AND uses the OEM sensor.
I manufacture a 6+1 TW for the GM OBD-1 PCM used on the USPS LLV.
I manufacture the MemCal for the GM OBD-I PCM.
I have done so for years, I have no report from Torque Head about what you ask.
Lance
Old Dec 7, 2017 | 05:13 PM
  #80
KW Baraka's Avatar
I would suggest calling them and asking about this kit in the link. It doesn't appear to be their complete conversion kit but it apparently will work on the '92s and '93s......
http://www.torqhead.com/buy-24xlink-...=0&sort=normal
Call us by phone by calling 1-226-289-3369 or by email at sales@torqhead.com for more details
KW
