Advice for high IAC counts
The engine is a 383 CI with forged Lunati crank, Eagle H beam rods, SRP forged pistons, ~9.6:1 SCR. AFR 210 competition ported eliminator heads with custom AI cam (~.55 range, and 116 LSA), Comp 1.6 ultra pro mags, LS7 lifters. STS turbo running only 5 psi now until I get tuning done. LT4 intake manifold ported for monoblade TB, that I have UN-modified to restore the idle air port.
I got it running with a Professional Products 58mm TB over the weekend, but IAC's were pegging at 130. I did the "drill mod" in the TB and incrementally went up to 7/32" hole (on the high end from what I've found on this and other forums), but IAC's are still around 85 at startup, and work their way up to 130 as it warms up. I have the idle speed set to 900 rpm, but plan to lower it down to 700-800 later on, which should help. I can get the IACs down if I open the throttle blades slightly, but this is not ideal since it is dumping air into the plenum rather than using the idle air passages. So my question is basically this... should I continue to drill the idle hole larger, or use the idle screw to open the blades slightly?
stock hole is 1/8" in TB. You are now at 7/32 and IAC is dropping. My TB I wound up at 11/64" to get them to 35 at idle but every set-up is different
Given your IAC hole is now 7/32, maybe doing a "slight" blade adjustment and then the hole slot mod on the TPS will be your formula.
you could try drilling the hole 1/64" larger to see if that gets you from 85 closer to 35 at idle......although there is no "reverse" of the drill mod hole size.
Might want to check your TPS vdc before next step and confirm as a base it is already in spec.
I think I am going to drop my idle RPMs to 700 and put the elbow back on for this process since there is a slight amount of air being pushed in from the turbo that's not accounted for right now. Like you said, once you drill bigger there's no going back smaller. Although I think I could insert a pop rivet or something to shrink it if worse came to worst.
1/64" does make quite a difference in IAC counts.
dropping the idle will affect IAC. If you can make tuning adjustments in your PCM might want to do that first and see what the IAC counts are
Also, I get terrible surging/bogging under deceleration. I'm hoping that resolves with the IAC in a better range.
The IAC needs head room above 35 ish for when power steering, AC or other accessories add load to the motor so it keeps it idling right
your surging/bogging may be a secondary result of the pegged IAC although it could also be programming. I assume you have a higher stall TC
I agree that the high IAC counts would suggest some kind of restriction somewhere(if all the electronics are working right).
