FYI, LT1/LT4 buildup......
Old Mar 25, 2016 | 07:26 AM
leadfoot4's Avatar
Default FYI, LT1/LT4 buildup......
..........is being covered as a 2 part "build up" in 'Chevy High Performance' magazine. Part 1 is in the June 2016 issue, which I received in the mail yesterday. Part 2, most likely, will be in the July issue...........
Old Mar 27, 2016 | 01:00 AM
KW Baraka's Avatar
Thanks for the heads-up!
KW
Old Mar 27, 2016 | 07:20 AM
rechtien's Avatar
http://www.superchevy.com/how-to/eng...engine-part-1/
Part 1.
Old Mar 29, 2016 | 12:19 PM
ahritchie's Avatar
This is supposed to be a "Stealthy" LT1 with a big red (and quite expensive red LT4 intake, BBK 58mm TB ) Seems like they could have done a lot better actually raising compression over stock LT4 levels, have the STOCK LT1 intake/heads ported buy a good porter, and get a stock TB ported to 52mm....so everything has stocklike stealth appearance (and make more power doing so to boot!)
Old Mar 29, 2016 | 03:35 PM
myltwon's Avatar
Problem is magazines base their builds on free/heavily discounted products from sponsors, hence while it's almost always off the shelf parts. I'm sure they'd be happy to run many of the ported stock casting packages if one of the companies was willing to buy ad space and throw them some free parts.
To be honest a red intake to pretty much anyone outside the LT1 circle means nothing to them, just that someone might have powdercoated/rattle canned an intake because they like red.
Old Mar 29, 2016 | 05:29 PM
leadfoot4's Avatar
To be honest a red intake to pretty much anyone outside the LT1 circle means nothing to them, just that someone might have powder coated/rattle canned an intake because they like red.
I agree..........
Old Mar 29, 2016 | 05:31 PM
Catmaigne's Avatar
I want to paint my LT4 intake black, is that sacrilege?
Old Mar 30, 2016 | 06:58 AM
myltwon's Avatar
Yes only acceptable aftermarket colors are hot pink or safety green
Old Mar 30, 2016 | 12:56 PM
bowtienut's Avatar
Pathetic build
Old Mar 31, 2016 | 04:22 PM
KW Baraka's Avatar
Originally Posted by bowtienut
Pathetic build
Yeah. The could've easily done more and still maintained drivability. That cam (SMH) would barely be interesting in a "cam only" upgrade.
It's definitely not what I would call a 'Performance Build'.
KW
Old Mar 31, 2016 | 07:29 PM
Casey96SS's Avatar
Pretty sure the opti and and water pump drive seals are designed to be installed dry too (if I remember correctly).
Part 2 in case no one saw it.
http://www.superchevy.com/how-to/eng...engine-part-2/
