Running Wires Into Cabin
Old Mar 29, 2016 | 10:59 AM
Snorkelface's Avatar
Default Running Wires Into Cabin
While I'm under the car, I wanted to get the wires for the electric cutout routed into the cabin. What's the best way to get wires through the transmission shift area without removing the transmission? I did a search and am not seeing this info.
Old Mar 29, 2016 | 11:14 AM
Shownomercy's Avatar
Man-Crush Warning
Pull up the carpet and find any of the many rubber drain plugs. Put a slice in one and feed your wire through up into the cabin.
Old Mar 29, 2016 | 02:35 PM
Would I generally find those in the the footwell areas, or should I start taking out the center console?
Old Mar 29, 2016 | 02:53 PM
Man-Crush Warning
Should be one under the seats, front and rear.
Old Mar 29, 2016 | 03:17 PM
Thanks, I'll give it a go!
Old Mar 29, 2016 | 03:31 PM
myltwon's Avatar
Manual or Auto?
Old Mar 29, 2016 | 03:49 PM
It's an auto.
Originally Posted by myltwon
Manual or Auto?
Old Mar 30, 2016 | 06:57 AM
myltwon's Avatar
Iirc I ended up running my wideband wires through the same grommet hole as the shift linkage
Old Mar 30, 2016 | 11:28 AM
That's what I was initially aiming for, but is there a trick to getting to that without dropping the trans?
Old Mar 30, 2016 | 12:15 PM
383z's Avatar
I've never had to do this, but do you think you could drop down a long string with a nut tied to the end as a weight from the top of the grommet hole where the shift linkage is and then tie your wire to the rope and pull it through the grommet hole where the linkage is?
Op, do you think this is possible?
Old Mar 30, 2016 | 02:14 PM
Sounds like a good idea. I wasn't sure if anything would obstruct something from freely heading down there.
Old Mar 30, 2016 | 07:53 PM
myltwon's Avatar
Well I can't remember exactly how I did it without looking at it but I definitely had the trans still in the car and only removed the center console. Just resealed around where I pulled the wire through with silicone. That s what I did for the wideband. I don't remember using anything fancy to accomplish it outside of maybe some hemostats or long needle nose pliers. Once you take out the console it's pretty easy to figure out.
Iirc I ran the cutout wires somewhere under the rear seats where there was another grommet beneath the carpet.
Old Mar 30, 2016 | 11:14 PM
Thumbs up
Thanks for the input, I'll look into that!
