Lt1 trans am idle issue?
Scan9495.zip
Did you change anything else with the LTCC conversion? If not, maybe the timing is way off?? The LTCC still uses the Optical Position Sensor, so it must still be installed correctly for everything to work right. If it's clocked off, it will have timing issues and run poorly, if it runs.
It could be a false rich condition, bad O2s maybe? Does it smell rich? Burning your eyes? If you have a cat, it'll mask a lot of it. But, if you are rich, you'll clog up the cat and foul out the plugs causing even more issues later.
