Weak spark, no start 1993 Corvette
So Opti is good. ICM is good. Injectors are pulsing. But still no start. It tries to, but just dies. I've tried to Data log it but can't get tuner pro RT to connect to the pcm, Damn CCM.
I'll need to check actual fuel pressure, the pump is priming and I can smell the fuel when trying to crank it. Maybe a leaking injector? Injectors are new, but the owner put in Accel injectors (this is before he brought me the car).
Any ideas?
You have gone through what would typically cause this issue....but, if you have not, check the wires that are all together at the coil/head mount on DS. A crack/break in one of those wires will cause a no run condition. Un-tape them and look carefully for any cracks/breaks in a wire.
Long shot but happened to me....the 4 pin connector that goes in opti. Remove it and carefully tug each wire at connector. My brown wire was never crimped when made and caused several sudden no start/run issues until I gave a small tug (read just touched it) and the brown wire just came out.
You will have to find your own needle in the haystack. Good luck
I'll have to get a new fuel pressure gauge as my adapter got lost in my last move. I'll have to find some time to get to a parts store and buy one, lol.
After that it'll be a compression check.
Alright all, I got me a new fuel pressure gauge from Auto Zone. Hooked it up and primed to 5 psi..... 5. 5 freakin PSI. Not to be without question, I tested the gauge on my Camaro, 45 PSI during prime, holds 38 after prime. So the gauge isn't faulty, the Corvette has 5 PSI of fuel pressure.
So I found the reason for no start. This doesn't explain the weak spark, but MAYBE the spark is weak due to battery only and maybe the battery doesn't have enough juice to crank the motor AND give strong spark at the same time?? I did trickle charge the battery, but I've been doing all the tests on just battery and I didn't check for spark strength until I had tried to get it to start checking everything else I just installed first.
New question. I have my stock fuel pump (just the motor) from my Camaro sitting on the shelf in my garage. Does anyone know if the pump motors are the same between the Vette and F-Bodies??
Thanks everyone.
Since you have to pull the one from the Vette, compare it to the one you have from Camaro. If same physical size I would think it would work as both have the LT1 motor
and yeah a FP gauge is a must have in the tool box :-)
assume you could do the same with the Y body.
If you have 5.5psi, fuel filter, then pull the tank and look at the pumps. You have to replace it anyways, even dangling the spare in there to fire it will eliminate that.
It is obvious this car sat around for a while though. Lots of surface rust on the pump sending unit. The sock was black too. Just got to put some fuel in her and give her a test run.
